Zero flux in plasma implantion and TDS
Hi,I’m trying to fit a irradiation of tungsten sample by deuterium plasma and subsequent TDS.But I found that the flux is 0 everywhere.I would like to know why this situation occurred.
Here’s my code:
vertices = np.concatenate([
    np.linspace(0, 3e-3, num=300),
my_model.mesh = F.MeshFromVertices(vertices)
    D_0=2.9e-7,  # m2/s
    E_D=0.29,  # eV
my_model.materials = tungsten
implantation_time = 9000  # s
ion_flux = sp.Piecewise((2.3e22, F.t <= 1800),
                        (1.9e22, (F.t>1800) & (F.t <= 3600)),
                        (1.03e22, (F.t>3600) & (F.t <= 5400)),
                        (6.23e21, (F.t>5400) & (F.t <= 7200)),
                        (2.5e21, (F.t>7200) & (F.t <= 9000)),
                        (0, True))
source_term = F.ImplantationFlux(
    flux=ion_flux,  # H/m2/s
    imp_depth=4e-9,  # m
    width=2e-9,  # m
    volume=1
my_model.sources = [source_term]
w_atom_density = 6.3e28  # atom/m3
n1=5e-3
n2=8e-3
n3=5e-2
        k_0=2.9e12/w_atom_density,
        E_k=0.29,
        E_p=0.95,
        density=sp.Piecewise((n1*w_atom_density, F.x <= 10e-6),
                             (0,True)),
        materials=tungsten
trap_2 = F.Trap(
        E_k=0.29,
        E_p=1.3,
        density=n2*w_atom_density,
        materials=tungsten
trap_3 = F.Trap(
        E_k=0.29,
        E_p=1.6,
        density=sp.Piecewise((n3*w_atom_density, F.x <= 1.4e-6),
                             (0,True)),
        materials=tungsten
my_model.traps = [trap_1, trap_2, trap_3]
    F.DirichletBC(surfaces=[1, 2], value=0, field=0)
implantation_temp = sp.Piecewise(
        (F.t,F.t<=560),
        (560, (F.t>560)&(F.t <= 2260)),
        (560 - (F.t-2260),(F.t >2260) & (F.t<=2283)),
        (527,(F.t>2283) &(F.t<=3500) ),
        (527-(F.t-3500),(F.t>3500)&(F.t<=3532)),
        (495,(F.t>3532) &(F.t<=5300)),
        (495-(F.t-5300), (F.t>5300)&(F.t<=5325)),
        (470,(F.t>5325)&(F.t<=7000)),
        (470-(F.t-7000),(F.t>7000)&(F.t<=7095)),
        (375,(F.t>7095)&(F.t<=8925)),
        (375-(F.t-8925),(F.t>8925)&(F.t<=9000)),
	    (300,True)) # K
temperature_ramp = 1  # K/s
start_tds = implantation_time + 50  # s
my_model.T = sp.Piecewise(
        (implantation_temp, F.t < 9000),
        (300,(F.t >9000) & (F.t<start_tds)),
        (300 + temperature_ramp*(F.t-start_tds), True))
    initial_value=0.5,
    max_stepsize=lambda t: 10 if t > start_tds else None,
    dt_min=1e-06,
    milestones=[implantation_time, start_tds],
    relative_tolerance=1e-9,
    final_time=15000
list_of_derived_quantities = [
        F.TotalVolume("2", volume=1),
        F.TotalVolume("3", volume=1),
        F.HydrogenFlux(surface=2)
    list_of_derived_quantities,
    filename="tds/derived_quantities.csv",  # optional set a filename to export the data to csv
    show_units=True,
my_model.exports = [derived_quantities]
t = derived_quantities.t
flux_left = derived_quantities.filter(fields="solute", surfaces=1).data
flux_right = derived_quantities.filter(fields="solute", surfaces=2).data
flux_total = -np.array(flux_left) - np.array(flux_right)
plt.plot(t, flux_total, linewidth=3)
plt.xlabel(r"Time (s)")
plt.savefig('pre-W-low.png')
Thank you!
Hi @Jellycarrot
Have you tried plotting your concentration fields by exporting to XDMF? this may give you some information about what is going on
I noticed the mesh you’re using is very coarse. This may be why everything is zero.
The volumetric source your are imposing is a gaussian centred on 4 nm with a stdev of 2nm, so very narrow. With such a coarse mesh, this source is so badly discretised that it’s zero everywhere.
You want to have local refinement as shown in the TDS tutorial of the workshop.
Something like
    np.linspace(0, 30e-9, num=200),
    np.linspace(30e-9, 3e-6, num=300),
    np.linspace(3e-6, 20e-6,num=200),
    np.linspace(20e-6, 3e-3, num=200),
Also, consider setting the log level to 20 in order to have more information about the newton iterations:
my_model.log_level = 20
Appreciate for your quick reply! Problem is solved.
Thanks for your time again!
