The initial flux isn't zero in TDS simulation
Hi,I’m doing 1D TDS simulation.The gas is deuterium,and the material is tungsten.
I found when I set E_p near to E_D(such as E_p = 0.6 and E_D = 0
.39),there will be a situation that the initial value of flux is not zero when the temperature is very low.
And here’s my code:
vertices = np.linspace(0, 1e-4,num = 1000)
my_model.mesh = F.MeshFromVertices(vertices)
atom_density =6.28e28
W = F.Material(
    D_0=2.9e-7,  # m2/s
    E_D=0.39,  # eV
my_model.materials = W
trap_conc = 7e-5*atom_density
my_model.initial_conditions = [
		F.InitialCondition(field="1", value=trap_conc)
        k_0=2.9e12/atom_density,
        E_k=0.39,
        p_0=2e13,
        E_p=1,
        density=trap_conc,
        materials= W
my_model.traps = [trap_1]
    F.DirichletBC(surfaces=[1, 2], value=0, field=0)
ramp = 1  # K/s
my_model.T = F.Temperature(value=300.1 + ramp * (F.t))
#Stepsize
    initial_value=0.1,
    dt_min=1e-6,
    max_stepsize=1,
#Settings
    absolute_tolerance=1e8,
    relative_tolerance=1e-12,
    final_time = 1173
list_of_derived_quantities = [
	F.AverageVolume(field="T", volume=1),
    list_of_derived_quantities,
    # filename="tds/derived_quantities.csv"  # optional set a filename to export the data to csv
my_model.exports = [derived_quantities]
t = derived_quantities.t
T = derived_quantities.filter(fields="T").data
flux_left = derived_quantities.filter(fields="solute", surfaces=1).data
flux_right = derived_quantities.filter(fields="solute", surfaces=2).data
flux_total = (-np.array(flux_left) - np.array(flux_right))/2
kk = flux_total.astype(str)
with open('10.txt', 'w') as file:
    for row in kk:
        file.write('\t'.join(map(str, row)) + '\n')
ref = np.genfromtxt('480k-0dpa.csv', delimiter=',')
tt = ref[:,0]
ttt = tt - 300.1
flux = ref[:,1]
plt.plot(t, flux_total, linewidth=0.5)
#plt.plot(ttt,flux)
plt.xlabel(r"t(s)")
plt.title("E=1,n=7e-5,0.1mm")
plt.savefig("guess10.png",dpi=600)
I wonder why that happens. Thank you!
Hi @Jellycarrot!
I suppose this behaviour, particularly the artifact at low temperatures for weak traps, is related to your initial conditions. Since hydrogen can escape from weak traps even at room temperatures, its initial “realistic” distribution at 300 K (i.e. one that could be obtained by simulating the exposure phase prior to TDS) might not correlate with the used one.
At lower initial temperatures, there are no artificats on TDS spectra:
For higher detrapping energies, the spectra shift to higher temperatures, so higher initial temperatures can be considered without any artifacts.
Please, let me know if it helps. Possibly, @remidm and @jhdark could provide more advices.
@Jellycarrot I believe that increasing the waiting time before the tds phase should also help removing this initial peak as the weak traps will dissociate.
Consider something like:
ramp = 1  # K/s
start_tds_time = 200  # s
T_value = sp.Piecewise(
    (300.1 + ramp * (F.t - start_tds_time), F.t >= start_tds_time),  # increase temp after sometime
    (300.1, True)  # otherwise T=300.1
my_model.T = F.Temperature(value=T_value)
Thank you!
That’s a good revolution to my problem.
Yes,it really help.I have tried,and the curve truly started from 0 at 200K.
But I’m trying to fit the experimental data, which is beginning at 300K.So,maybe I need to use Professor remidm’s method.
Anyway,thank you for you good advice and promt reply!
