The peak of the two-dimensional TDS spectrum can't be reduced to zero
Hi,I’m trying to draw a 2D TDS spectrum of tungsten containing one trap.
But I found the total flux need very long time to reach the peak and it won’t reduce to zero while the flux out of the trap drop to 0 very quickly.
And here’s my code:
model_2d = F.Simulation()
wu = F.Material(
    D_0=1.93e-7,
    E_D=0.2,
model_2d.materials = wu
from fenics import UnitSquareMesh, CompiledSubDomain, MeshFunction, plot
# creating a mesh with FEniCS
nx = ny = 20
mesh_fenics = UnitSquareMesh(nx, ny)
# marking physical groups (volumes and surfaces)
volume_markers = MeshFunction(
    "size_t", mesh_fenics, mesh_fenics.topology().dim())
volume_markers.set_all(1)
left_surface = CompiledSubDomain(
    'on_boundary && near(x[0], 0, tol)', tol=1e-14)
right_surface = CompiledSubDomain(
    'on_boundary && near(x[0], 1, tol)', tol=1e-14)
bottom_surface = CompiledSubDomain(
    'on_boundary && near(x[1], 0, tol)', tol=1e-14)
top_surface = CompiledSubDomain(
    'on_boundary && near(x[1], 1, tol)', tol=1e-14)
surface_markers = MeshFunction(
    "size_t", mesh_fenics, mesh_fenics.topology().dim() - 1)
surface_markers.set_all(0)
left_id = 1
top_id = 2
right_id = 3
bottom_id = 4
left_surface.mark(surface_markers, left_id)
right_surface.mark(surface_markers, right_id)
top_surface.mark(surface_markers, top_id)
bottom_surface.mark(surface_markers, bottom_id)
# creating mesh with festim
model_2d.mesh = F.Mesh(
    mesh=mesh_fenics,
    volume_markers=volume_markers,
    surface_markers=surface_markers
w_atom_density = 6.3e28  # atom/m3
    k_0= 1.93e-7/ (1.1e-10**2 * 6 * w_atom_density),
    E_k=0.2,
    E_p=0.87,
    density=1.3e-3*w_atom_density,
    materials=wu,
model_2d.traps = [trap_1]
model_2d.initial_conditions = [
	F.InitialCondition(field="1", value=1.3e-3*w_atom_density),
	F.InitialCondition(field="solute",value=0),
model_2d.boundary_conditions = [
        F.DirichletBC(surfaces=1, value=0, field=0),
	F.DirichletBC(surfaces=2, value=0, field=0),
        F.DirichletBC(surfaces=3, value=0, field=0),
	F.DirichletBC(surfaces=4, value=0, field=0),
ramp = 2  # K/s
model_2d.T = 300 + ramp * (F.t)
model_2d.dt = F.Stepsize(
    initial_value=0.01,
    dt_min=1e-6,
model_2d.settings = F.Settings(
    final_time=1000,
    maximum_iterations=100,
derived_quantities =F.DerivedQuantities(
	F.HydrogenFlux(surface=3),
	F.HydrogenFlux(surface=4),
	F.AverageVolume(field="T",volume=1),
model_2d.exports = [derived_quantities]
model_2d.initialise()
model_2d.run()
T = derived_quantities.filter(fields = "T").data
flux_left = derived_quantities.filter(fields="solute", surfaces=1).data
flux_top = derived_quantities.filter(fields="solute", surfaces=2).data
flux_right = derived_quantities.filter(fields="solute", surfaces=3).data
flux_buttom = derived_quantities.filter(fields="solute", surfaces=4).data
flux_trap1 = derived_quantities.filter(fields="1").data
mobile = derived_quantities.filter(fields="solute", instances=F.TotalVolume).data
total = derived_quantities.filter(fields="retention").data
flux_total = -np.array(flux_left) - np.array(flux_top) - np.array(flux_right) - np.array(flux_buttom)
#plt.plot(T, mobile, linewidth=3)
plt.plot(T, flux_total)
#plt.plot(T,flux_trap1)
plt.xlabel(r"T (K)")
plt.savefig('2d.png')
This really confused me,I’m looking forward to your reply.
Thank you!
Hi @Jellycarrot
As I see, you study the H transport on fenics.UnitSquareMesh. The default units for the length are meters. This means that the geometry size is 1 m \times 1 m in your simulation. The characteristic length of H diffusion is much smaller than the geometry length.
Here is an example of the total flux evolution at different sizes of the mesh side (L). The fluxes are normalised on the peak value:
To define a rectangular mesh, I used fenics.RectangleMesh:
mesh_fenics = f.RectangleMesh(f.Point(0,0), f.Point(L, L), nx, ny)
Please, let me know if it helps.
Oh my god, it’s really a rookie mistake.So embarrasing
Sorry for taking up your valueble time.
And thanks again for your prompt reply
