Second peak in TDS simulation for a single trap
Hi,
I’m working on thermo-desorption spectra of hydrogen in tungsten with FESTIM.However,there’s a question that troubles me:
Why does FESTIM’s TDS simulation for a single trap have a second peak after the first main peak?
Thanks!
Hi @Jellycarrot and welcome to FESTIM!
Do you have an example that you could share with us? A minimal working example that we could run.
A few ideas:
  • a peak of mobile particles
  • a desorption peak of the right hand side
But again it’s hard to tell without having a script
Thank you for your prompt attention!
Here is my code as an example
vertices = np.concatenate([
    np.linspace(0, 30e-9, num=200),
    np.linspace(30e-9, 49.97e-6, num=500),
    np.linspace(49.97e-6, 50e-6, num=200),
my_model.mesh = F.MeshFromVertices(vertices)
    D_0=4.1e-07,  # m2/s
    E_D=0.39,  # eV
my_model.materials = tungsten
implantation_time = 400  # s
ion_flux = sp.Piecewise((2.5e19, F.t <= implantation_time), (0, True))
source_term = F.ImplantationFlux(
    flux=ion_flux,  # H/m2/s
    imp_depth=4.5e-9,  # m
    width=2.5e-9,  # m
    volume=1
my_model.sources = [source_term]
w_atom_density = 6.3e28  # atom/m3
	k_0=4.1e-7/(1.1e-10**2*6*w_atom_density),
	E_k=0.39,
	p_0=2e13,
        E_p=1.25,
        density=2e-4*w_atom_density,
        materials=tungsten
my_model.traps = [trap_1]
    F.DirichletBC(surfaces=[1, 2], value=0, field=0)
#Temperature
implantation_temp = 300  # K
temperature_ramp = 1  # K/s
start_tds = implantation_time + 50  # s
my_model.T = F.Temperature(
    value=sp.Piecewise(
        (implantation_temp, F.t < start_tds),
        (implantation_temp + temperature_ramp*(F.t-start_tds), True))
#Stepsize
    initial_value=0.5,
    stepsize_change_ratio=1.1,
    max_stepsize=lambda t: 0.5 if t > start_tds else None,
    dt_min=1e-05,
    milestones=[implantation_time, start_tds],
#Settings
    relative_tolerance=1e-09,
    final_time=1000
list_of_derived_quantities = [
        F.HydrogenFlux(surface=2)
    list_of_derived_quantities,
    # filename="tds/derived_quantities.csv"  # optional set a filename to export the data to csv
my_model.exports = [derived_quantities]
t = derived_quantities.t
flux_left = derived_quantities.filter(fields="solute", surfaces=1).data
flux_right = derived_quantities.filter(fields="solute", surfaces=2).data
flux_total = -np.array(flux_left) - np.array(flux_right)
plt.plot(t, flux_total, linewidth=3)
plt.xlabel(r"Time (s)")
plt.savefig('1.png')
trap_1 = derived_quantities.filter(fields="1").data
contribution_trap_1 = -np.diff(trap_1)/np.diff(t)
plt.plot(t[1:], contribution_trap_1, linestyle="--", color="grey")
plt.fill_between(t[1:], 0, contribution_trap_1, facecolor='grey', alpha=0.1)
plt.xlim(450, 1000)
plt.ylim(bottom=-0.05e18, top=0.6e18)
plt.savefig("2.png",dpi=600)
In the code above (which is slightly modified from your Task 02 in FESTIM-workshop),I try to run a system of 50μm with single trap.
Then I’ve got two graphs like this:
jyz
So I wonder how did the second peak appear.
Thanks again for answering me!
Instead of plotting contribution_trap_1 can you plot flux_left and flux_right instead?
@Jellycarrot I confirm this is the desorption from the right hand side
plt.plot(t, flux_total, linewidth=3, color="black")
plt.stackplot(
    t,
    -np.array(flux_left),
    -np.array(flux_right),
    colors=["tab:blue", "tab:orange"],
    labels=["Left", "Right"],
If you increase the sample size to say 1 mm then this peak disappears:
This is because when you have a thin sample, after detrapping, hydrogen diffuses to both sides and there is a small delay after which it has reached the right side. This also happens with thicker samples except there is a much larger distance to diffuse through and therefore H only desorbs from the left.
Thank you,It really helps!
I plot too:
My problem is solved.
Wish you have a good day!
