Simulation doesn't converge under local traps condition
Hi,I’m trying to fit 1D TDS simulation of deuterium in tungsten with FESTIM.But since I used sp.Piecewise to set local depth traps,the Newton solver wouldn’t converge.I wonder where my settings went wrong.Thank you!
Here’s my code and raw experimental data:
import warnings
warnings.filterwarnings("ignore", category=DeprecationWarning)
def TDS(h1,n1, E_p1,h2,n2,E_p2):
    """Runs the simulation with parameters p that represent:
        n (float): concentration of trap 1, at. fr.
        E_p (float): detrapping barrier from trap 1, eV
    Returns:
        F.DerivedQuantities: the derived quantities of the simulation
    atom_density = 6.28e28  # atom/m3
    # Define Simulation object
    synthetic_TDS = F.Simulation()
    synthetic_TDS.log_level = 40
    # Define a simple mesh
    vertices = np.concatenate([
               np.linspace(0, 1e-4, num=100),
               np.linspace(1e-4, 5e-4, num=200),
               np.linspace(5e-4, 1.5e-3, num=200),
    synthetic_TDS.mesh = F.MeshFromVertices(vertices)
    trap_conc1 = sp.Piecewise((n1 * atom_density,F.x< h1),
                              (0,True))
    trap_conc2 = sp.Piecewise((n2 * atom_density,F.x< h2),
                              (0,True))
    # Define material properties
    W = F.Material(
        D_0=2.9e-7,
        E_D=0.39,
    synthetic_TDS.materials = W
    # Define traps
        k_0=2.9e12/atom_density,
        E_k=0.39,
        E_p=E_p1,
        density=trap_conc1,
        materials=W,
    trap_2 = F.Trap(
        E_k=0.39,
        E_p=E_p2,
        density=trap_conc2,
        materials=W,
    synthetic_TDS.traps = [trap_1,trap_2]
    # Set initial conditions
    synthetic_TDS.initial_conditions = [
        F.InitialCondition(field="1", value=trap_conc1),
	F.InitialCondition(field="2", value=trap_conc2),
    # Set boundary conditions
    synthetic_TDS.boundary_conditions = [
        F.DirichletBC(surfaces=[1, 2], value=0, field=0)
    # Define the material temperature evolution
    ramp = 1  # K/s
    synthetic_TDS.T = F.Temperature(value=317.8+ ramp * (F.t))
    # Define the simulation settings
    synthetic_TDS.dt = F.Stepsize(
        initial_value=1,
        dt_min=1e-6,
        max_stepsize=2)
    synthetic_TDS.settings = F.Settings(
        absolute_tolerance=1e12,
        relative_tolerance=1e-8,
        final_time=1154,
        maximum_iterations=100,
    # Define the exports
            F.AverageVolume(field="T", volume=1),
    synthetic_TDS.exports = [derived_quantities]
    synthetic_TDS.initialise()
    synthetic_TDS.run()
    return derived_quantities
ref = np.genfromtxt('480k-1dpa.csv', delimiter=',')
T = ref[:, 0]
flux = ref[:, 1]
def info(i, p):
    Print information during the fitting procedure
    print("-" * 40)
    print(f"i = {i}")
    print("New simulation.")
    print(f"Point is: {p}")
from scipy.interpolate import interp1d
prms = []
errors = []
def error_function(prm):
    Compute average absolute error between simulation and reference
    global i
    global prms
    global errors
    prms.append(prm)
    i += 1
    info(i, prm)
    # Filter the results if a negative value is found
    if any([e < 0 for e in prm]):
        return 1e30
    # Get the simulation result
    h1,n1, Ep1,h2,n2,Ep2 = prm
    res = TDS(h1,n1, Ep1,h2,n2,Ep2)
    T = np.array(res.filter(fields="T").data)
    flux = -np.array(res.filter(fields="solute", surfaces=1).data) - np.array(
        res.filter(fields="solute", surfaces=2).data)
    # Plot the intermediate TDS spectra
    if i == 1:
        plt.plot(T, flux, color="tab:red", lw=2, label="Initial guess")
        plt.plot(T, flux, color="tab:grey", lw=0.5)
    interp_tds = interp1d(T, flux, fill_value="extrapolate")
    # Compute the mean absolute error between sim and ref
    err = np.nanmean(np.abs(interp_tds(ref[:, 0]) - ref[:, 1]).mean())
    print(f"Average absolute error is : {err:.2e}")
    errors.append(err)
    return err
from scipy.optimize import minimize
i = 0  # initialise counter
# Set the tolerances
fatol = 1e16
xatol = 1e-3
initial_guess = [0.0005,0.0005,1,0.0005,0.001,1.26]
# Minimise the error function
res = minimize(
    error_function,
    np.array(initial_guess),
    method="Nelder-Mead",
    options={"disp": True, "fatol": fatol, "xatol": xatol},
# Process the obtained results
predicted_data = TDS(*res.x)
T = predicted_data.filter(fields="T").data
flux_left = predicted_data.filter(fields="solute", surfaces=1).data
flux_right = predicted_data.filter(fields="solute", surfaces=2).data
flux_total = -(np.array(flux_left) + np.array(flux_right))
# Visualise
plt.plot(ref[:, 0], ref[:, 1], linewidth=2, label="Reference")
plt.plot(T, flux_total, linewidth=2, label="Optimised")
plt.xlabel(r"Temperature (K)")
plt.savefig('480k-1dpa.png')
reference_prms = [E_p, trap_conc]
plt.scatter(
    np.array(prms)[:, 0], np.array(prms)[:, 1], c=np.array(errors), cmap="viridis"
plt.plot(np.array(prms)[:, 0], np.array(prms)[:, 1], color="tab:grey", lw=0.5)
plt.scatter(*reference_prms, c="tab:red")
plt.annotate(
    "Reference",
    xy=reference_prms,
    xytext=(reference_prms[0] - 0.003, reference_prms[1] + 0.1),
    arrowprops=dict(facecolor="black", arrowstyle="-|>"),
plt.annotate(
    "Initial guess",
    xy=initial_guess,
    xytext=(initial_guess[0] - 0.004, initial_guess[1] + 0.05),
plt.xlabel(r"Trap 1 concentration (at. fr.)")
plt.ylabel(r"Detrapping barrier (eV)")
plt.savefig('scatter.png')
480k-1dpa.zip (4.9 KB)
Hi @Jellycarrot your code is a bit long and hard to parse. Can you make a minimal working example showing your issue?
For example, to show the simulation isn’t converging, you don’t need to have:
  • the experimental data
  • the optimisation
  • the error calculation
  • the info function
  • the plotting
OK Professor Remi,thanks for your prompt reply.
Here’s a single simulation:
#Simulation of a Thermo-Desorption experiment
import warnings
vertices = np.linspace(0,1.5e-3,num =1500)
my_model.mesh = F.MeshFromVertices(vertices)
atom_density =6.28e28
W = F.Material(
    D_0=2.9e-7,  # m2/s
    E_D=0.39,  # eV
my_model.materials = W
trap_conc1 = sp.Piecewise((5e-4 * atom_density, F.x < 1e-3),
                          (0, True))
trap_conc2 = sp.Piecewise((1e-3 * atom_density, F.x < 1.5e-6),
                          (0, True))
my_model.initial_conditions = [
        E_k=0.39,
        E_p=1,
        density=trap_conc1,
        materials= W
trap_2 = F.Trap(
        E_k=0.39,
        E_p=1.26,
        density=trap_conc2,
        materials= W
my_model.traps = [trap_1,trap_2]
ramp = 1  # K/s
my_model.T = F.Temperature(value=304 + ramp * (F.t))
#Stepsize
    initial_value=0.1,
    dt_min=1e-6,
    max_stepsize=1,
#Settings
    final_time = 1167
list_of_derived_quantities = [
	F.TotalVolume("2",volume=1),
    list_of_derived_quantities,
    # filename="tds/derived_quantities.csv"  # optional set a filename to export the data to csv
my_model.exports = [derived_quantities]
t = derived_quantities.t
T = derived_quantities.filter(fields="T").data
flux_left = derived_quantities.filter(fields="solute", surfaces=1).data
flux_right = derived_quantities.filter(fields="solute", surfaces=2).data
flux_total = (-np.array(flux_left) - np.array(flux_right))
kk = flux_total.astype(str)
#with open('11.txt', 'w') as file:
    #for row in kk:
        #file.write('\t'.join(map(str, row)) + '\n')
plt.plot(T, flux_total,label="Simulation")
plt.xlabel(r"T(K)")
plt.title("480k-1dpa")
plt.savefig("480-1.png",dpi=600)
Hi @Jellycarrot
Consider setting traps_element_type="DG" in the model settings and optimising your mesh. With the following code I managed to obtain a TDS specturm.
Code
        np.linspace(0, 1.5e-6, num=250),
        np.linspace(1.5e-6, 1e-3, num=500),
        np.linspace(1e-3, 1.5e-3, num=500),
W = F.Material(
    D_0=2.9e-7,  # m2/s
    E_D=0.39,  # eV
trap_conc1 = sp.Piecewise((5e-4 * atom_density, F.x < 1e-3), (0, True))
trap_conc2 = sp.Piecewise((1e-3 * atom_density, F.x < 1.5e-6), (0, True))
    k_0=2.9e12 / atom_density,
    E_k=0.39,
    E_p=1,
    density=trap_conc1,
    materials=W,
trap_2 = F.Trap(
    E_k=0.39,
    E_p=1.26,
    density=trap_conc2,
    materials=W,
my_model.traps = [trap_1, trap_2]
my_model.boundary_conditions = [F.DirichletBC(surfaces=[1, 2], value=0, field=0)]
ramp = 1  # K/s
# Stepsize
    initial_value=0.01,
    stepsize_change_ratio=1.05,
    dt_min=1e-6,
    max_stepsize=1,
# Settings
    final_time=1167,
    traps_element_type="DG",
flux_total = -np.array(flux_left) - np.array(flux_right)
plt.plot(T, flux_total, label="Simulation")
plt.xlabel(r"T(K)")
The result:
