Checkpoints not working in multi-material simulations
Hello everyone,
I’ve been using festim 2.0b0 (up to date to the latest commit in the fenicsx branch) to run 1D simulations in a single-material slab. I was restarting simulations from checkpoints and using the “read_function_from_file” function to load the initial conditions.
I tried running similar simulations now for the multi-material case and it seems like the checkpointing is not implemented for these cases.
Here is the script that I’m using:
from ufl import conditional, And, ge, lt
def linear_piecewise_ufl(t, times, values):
assert len(times) == len(values) and len(times) >= 2
expr = values[0]
for i in range(len(times) - 1):
t0, t1 = float(times[i]), float(times[i + 1])
v0, v1 = float(values[i]), float(values[i + 1])
slope = (v1 - v0) / (t1 - t0)
seg = v0 + slope * (t - t0)
expr = conditional(And(ge(t, t0), lt(t, t1)), seg, expr)
expr = conditional(ge(t, float(times[-1])), float(values[-1]), expr)
return expr
thick_W = 2e-3
thick_SS = 5e-3
vertices = np.concatenate([
np.linspace(0, thick_W, 300),
np.linspace(thick_W, thick_W+thick_SS, 400)[1:],  # avoid duplicate node at thick_W
mesh = F.Mesh1D(vertices)
TUNGSTEN = F.Material(D_0=1.9e-7, E_D=0.2, K_S_0=4.52e21, E_K_S=0.3, name=“W”)
SS316L  = F.Material(D_0=1.45e-6, E_D=0.59, K_S_0=1.38e23, E_K_S=0.0883, name=“SS”)
vol_W  = F.VolumeSubdomain1D(id=1, borders=[0, thick_W], material=TUNGSTEN)
vol_SS = F.VolumeSubdomain1D(id=2, borders=[thick_W, thick_W + thick_SS], material=SS316L)
surf_in  = F.SurfaceSubdomain1D(id=1, x=0)
surf_out = F.SurfaceSubdomain1D(id=2, x=thick_W + thick_SS)
interface_WSS = F.Interface(id=1, subdomains=[vol_W, vol_SS])
my_model = F.HydrogenTransportProblemDiscontinuous()
my_model.mesh = mesh
my_model.subdomains = [vol_W, vol_SS, surf_in, surf_out]
my_model.interfaces = [interface_WSS]
my_model.surface_to_volume = {surf_in: vol_W, surf_out: vol_SS}
mobile_T   = F.Species(“T”, subdomains=[vol_W, vol_SS])
trapped_SS = F.Species(“trapped_SS”, mobile=False, subdomains=[vol_SS])
trapped_W  = F.Species(“trapped_W”,  mobile=False, subdomains=[vol_W])
ss_atom_density = 8.45e28
w_atom_density  = 6.3e28
empty_trap_SS = F.ImplicitSpecies(name=“empty_trap_SS”, n=0.0008 * ss_atom_density, others=[trapped_SS])
empty_trap_W  = F.ImplicitSpecies(name=“empty_trap_W”,  n=1.0e-4 * w_atom_density,  others=[trapped_W])
D0E, EDE = 1.45e-6, 0.59
D0W, EDW = 1.9e-7, 0.2
reaction_trap_1 = F.Reaction(
k_0=D0E / (3.5935e-102 * ss_atom_density), E_k=EDE,
p_0=8.53e13, E_p=0.7,
reactant=[mobile_T, empty_trap_SS], product=[trapped_SS], volume=vol_SS,
reaction_trap_W1 = F.Reaction(
k_0=D0W / (1.1e-102 * 6 * w_atom_density), E_k=EDW,
p_0=1e13, E_p=0.87,
reactant=[mobile_T, empty_trap_W], product=[trapped_W], volume=vol_W,
my_model.species = [mobile_T, trapped_SS, trapped_W]
my_model.reactions = [reaction_trap_1, reaction_trap_W1]
time_points  = [0, 100, 200, 300]
power_points = [0, 1, 1, 0]
base_temp   = 300.0
peak_temp_W = 1200.0
peak_temp_SS = 800.0
def T_profile(x, t):
P = linear_piecewise_ufl(t, time_points, power_points)
TL_W  = base_temp + P * (peak_temp_W  - base_temp)
TL_SS = base_temp + P * (peak_temp_SS - base_temp)
TR_W, TR_SS = TL_W, TL_SS
TW  = TL_W  + (TR_W  - TL_W)  * (x[0]) / thick_W
TSS = TL_SS + (TR_SS - TL_SS) * (x[0] - thick_W) / thick_SS
return conditional(lt(x[0], thick_W), TW, TSS)
my_model.temperature = T_profile
j0 = 1e20
PTVu, PL, PTVd = 50, 200, 50
RE, RP = 1.0, 4.5e-9
kb = 1.38e-23
eV = 1.602176634e-19
K0W, EKW = 7.94e-17, -2.0
def P_num(t: float) → float:
return float(np.interp(t, time_points, power_points))
def Tsurf(t: float) → float:
return base_temp + P_num(t) * (peak_temp_W - base_temp)
def ion_flux_scalar(t: float) → float:
if t < PTVu:
return j0 * t / PTVu
elif t < PTVu + PL:
return j0
elif t < PTVu + PL + PTVd:
return j0 * (PTVu + PL + PTVd - t) / PTVd
return 0.0
def surface_conc(t: float) → float:
Ts = Tsurf(t)
DE = D0W * np.exp(-EDW * eV / (kb * Ts))
KE = K0W * np.exp(-EKW * eV / (kb * Ts))
phi = max(ion_flux_scalar(t), 0.0)
return RE * phi * RP / DE + np.sqrt(phi / KE)
F.FixedConcentrationBC(subdomain=surf_in,  species=mobile_T, value=lambda t: surface_conc(t)),
F.FixedConcentrationBC(subdomain=surf_out, species=mobile_T, value=lambda t: 0.0),
transient=True,
final_time=PTVu + PL + PTVd,
atol=1e11,
rtol=1e-9,
max_iterations=500,
stepsize=F.Stepsize(
1e-12,
growth_factor=1.1,
cutback_factor=0.1,
target_nb_iterations=5,
max_stepsize=1,
milestones=time_points,
F.VTXSpeciesExport(“results/mobile_conc_W.bp”,  field=mobile_T,  subdomain=vol_W),
F.VTXSpeciesExport(“results/mobile_conc_SS.bp”, field=mobile_T,  subdomain=vol_SS),
F.VTXSpeciesExport(“results/trapped_W.bp”,      field=trapped_W, subdomain=vol_W),
F.VTXSpeciesExport(“results/trapped_SS.bp”,     field=trapped_SS, subdomain=vol_SS),
F.VTXSpeciesExport(“results/mobile_conc_W.bp”,  field=mobile_T,  subdomain=vol_W,  checkpoint=True, times=time_points),
F.VTXSpeciesExport(“results/mobile_conc_SS.bp”, field=mobile_T,  subdomain=vol_SS, checkpoint=True, times=time_points),
F.VTXSpeciesExport(“results/trapped_W.bp”,      field=trapped_W, subdomain=vol_W,  checkpoint=True, times=time_points),
F.VTXSpeciesExport(“results/trapped_SS.bp”,     field=trapped_SS, subdomain=vol_SS, checkpoint=True, times=time_points),
And the full error message:
File “/home/ITER/llealsa/multimaterial_dolfinx10/minimal.py”, line 150, in
File “/home/ITER/llealsa/miniconda3/envs/festim-fenicsx/lib/python3.11/site-packages/festim/hydrogen_transport_problem.py”, line 1209, in initialise
self.initialise_exports()
File “/home/ITER/llealsa/miniconda3/envs/festim-fenicsx/lib/python3.11/site-packages/festim/hydrogen_transport_problem.py”, line 1701, in initialise_exports
raise NotImplementedError(
NotImplementedError: Export type <class ‘festim.exports.vtx.VTXSpeciesExport’> not implemented for mixed-domain approach
When commenting the checkpointing exports, the simulation runs without giving any errors.
I was wondering if there’s an alternative way to export checkpoints and load them as initial conditions in this current version.
Thank you very much for your help!
The error message seems to suggest that checkpointing is not implemented for the mixed-domain approach (ie. multi-material). We have an open issue about this: IC from checkpoint in mixed-domain · Issue #1021 · festim-dev/FESTIM · GitHub
It seems we need to wait for some changes in adios4dolfinx in order to support it: Submesh support · Issue #149 · jorgensd/adios4dolfinx · GitHub
It seems we should be able to write several stand alone grids as checkpoints (one for each material and species)!
@AdriaLlealS is there an open issue for this on FESTIM?
Hi @remidm, sorry just saw this right now. Just checked and I never opened an issue for it, I didn’t see any open issue related to it either
Would you mind opening one?
It seems checkpointing in multi-material simulations is working without issues in the latest version of festim!
