Interface condition issue in multi-material diffusion with mixed solubility laws
I recently switched to FESTIM2 (v2.0b1) and ran into an issue when running multi-material simulations using the discontinuous formulations. While benchmarking against FESTIM1, I found that in certain cases the interface condition does not appear to be enforced correctly when using HydrogenTransportProblemDiscontinuous().
To investigate this, I benchmarked the following three implementations against each other:
  • FESTIM1
  • HydrogenTransportProblemDiscontinuous()
  • HydrogenTransportProblemDiscontinuousChangeVar()
The physical problem was kept simple. I am looking at a 2D multi-material three-body setup:
Wall | Fluid | Wall
The physics is diffusion only (no advection). I apply a fixed concentration of 1e20 on the left boundary and zero concentration on the right boundary. The wall material is Eurofer, and the fluid material is either Helium or LiPb. In addition, I also tested dummy material properties (Dummy1 for the fluid and Dummy2 for the walls) to check the robustness of the formulations.
The solubility-law combinations I tested are:
  • Sieverts | Henry | Sieverts (Eurofer with Helium)
  • Sieverts | Sieverts | Sieverts (Eurofer with LiPb and Dummy1 and Dummy2).
    What I observe is that FESTIM1 and HydrogenTransportProblemDiscontinuousChangeVar() give very comparable results, while HydrogenTransportProblemDiscontinuous() produces qualitatively different ones.
    The table below shows three test cases I ran. The shown figures describe the concetration profile between the two boundaries.
For the cases for HydrogenTransportProblemDiscontinuous(), the change of concentration across the interface is inverse to that of the other two cases when realistic material properties are used. All 3 approaches coinside for the dummy materials values.
FESTIM1 and the ChangeVar() are similar especially for the first and third case which makes sense as they are solving, as I understand, the same transport equations. In the second case they differ as HydrogenTransportProblemDiscontinuousChangeVar() is not considering the solubility law difference.
I explicitly checked the concentration jump at the interface against the theoretical jump expected from the solubility ratios. Using the simulated concentrations on both sides of the interface, the results from FESTIM1 and HydrogenTransportProblemDiscontinuousChangeVar() match expectations, whereas the results from HydrogenTransportProblemDiscontinuous() do not.
I tried global mesh refinement, but this did not resolve the issue (I am not refining specifically at the interface which might be something to try next).
To isolate the problem further, I tested the same setups using dummy material properties (case 3). In that case, HydrogenTransportProblemDiscontinuous() matches the results from the other two implementations for purely Sieverts-type materials.
What I find particularly confusing is that once realistic material properties are used, HydrogenTransportProblemDiscontinuous() seems unable to impose the correct interface condition, even though it behaves as expected with dummy properties.
I also encountered issues when using the penalty interface method. For cases with different solubility laws, the solver does not converge, regardless of whether realistic or dummy material properties are used. Mesh refinement did not help in this case either.
At this point, I am unsure what the cause of this is and how to resolve it.
If anyone has insight into this behavior, knows of constraints on material parameters, or can suggest a recommended strategy, I would appreciate the help.
A minimal working script with all material properties is provided below for FESTIM2.
from dolfinx.mesh import create_rectangle, create_unit_square
import dolfinx
from dolfinx import plot
import pyvista as pv
from pathlib import Path
import h_transport_materials as htm # Material properties
inlet_id=1
outlet_id=2
wall_id=3
axis_id=4
fluid_id=5
left_wall_id = 6
right_wall_id = 7
interface_l_id = 8
interface_r_id = 9
pipe_id=10
wall_l_thickness = 0.005
wall_r_thickness = 0.005
r_max=0.02
z_max=0.1
nx=100
ny=250
r_min=0.005
z_min=0
#set simulation typ
my_sim = F.HydrogenTransportProblemDiscontinuous()
#my_sim = F.HydrogenTransportProblemDiscontinuousChangeVar()
#generate Mesh
mesh_fenics = create_rectangle(MPI.COMM_WORLD,[[r_min-wall_l_thickness,z_min],[r_max+wall_r_thickness,z_max]],[nx,ny])
#define Material properties
Dummy1 = F.Material(D_0=1,E_D=0,K_S_0=2,E_K_S=0,solubility_law="SIEVERT") #HENRY SIEVERT
Dummy2 = F.Material(D_0=2,E_D=0,K_S_0=3,E_K_S=0,solubility_law="SIEVERT")
S_0=9.0537131e19
D_0=8.83757e-06
He = F.Material(D_0=D_0, E_D=0, K_S_0=S_0, E_K_S=0,solubility_law='HENRY')
D_pbli = (htm.diffusivities.filter(material="lipb").filter(isotope="h").filter(author="reiter"))[0]
S_pbli = (htm.solubilities.filter(material="lipb").filter(isotope="h").filter(author="aiello"))[0]
PbLi = F.Material(
    D_0=D_pbli.pre_exp.magnitude,
    E_D=D_pbli.act_energy.magnitude,
    K_S_0=S_pbli.pre_exp.magnitude,
    E_K_S=S_pbli.act_energy.magnitude,
D_eurofer = htm.diffusivities.filter(material="eurofer_97").filter(author="chen")[0]
S_eurofer = htm.solubilities.filter(material="eurofer_97").filter(author="chen")[0]
Eurofer = F.Material(
    D_0=D_eurofer.pre_exp.magnitude,
    E_D=D_eurofer.act_energy.magnitude,
    K_S_0=S_eurofer.pre_exp.magnitude,
    E_K_S=S_eurofer.act_energy.magnitude,
#assign surfaces
inlet_boundary = F.SurfaceSubdomain(id=inlet_id, locator=lambda x: (np.isclose(x[1], z_min) & (x[0] >= r_min) & (x[0] <= r_max)))
outlet_boundary = F.SurfaceSubdomain(id=outlet_id,locator=lambda x: (np.isclose(x[1], z_max) & (x[0] >= r_min) & (x[0] <= r_max)))
inner_wall_boundary = F.SurfaceSubdomain(id=axis_id, locator=lambda x: np.isclose(x[0], r_min-wall_l_thickness))
outer_wall_boundary = F.SurfaceSubdomain(id=wall_id, locator=lambda x: np.isclose(x[0], r_max+wall_r_thickness))
#assign Volumes
fluid_subdomain = F.VolumeSubdomain(id=fluid_id,material=He,locator=lambda x: (x[0]>=r_min) & (x[0]<=r_max))
#fluid_subdomain = F.VolumeSubdomain(id=fluid_id,material=PbLi,locator=lambda x: (x[0]>=r_min) & (x[0]<=r_max))
#fluid_subdomain = F.VolumeSubdomain(id=fluid_id,material=Dummy1,locator=lambda x: (x[0]>=r_min) & (x[0]<=r_max))
left_wall = F.VolumeSubdomain(
    id=left_wall_id, material=Eurofer, #Dummy2 Eurofer
    locator=lambda x: x[0] <= r_min
right_wall = F.VolumeSubdomain(id=right_wall_id, material=Eurofer #Dummy2 Eurofer
                               ,locator=lambda x: x[0] >= r_max)
#setup Mesh and interfaces
my_sim.mesh=F.Mesh(mesh_fenics)
my_sim.subdomains = [
    outer_wall_boundary,
    inner_wall_boundary,
    inlet_boundary,
    outlet_boundary,
    fluid_subdomain,
    right_wall,
    left_wall,
my_sim.interfaces = [
    F.Interface(interface_l_id, (fluid_subdomain, left_wall),  penalty_term=1000),
    F.Interface(interface_r_id, (fluid_subdomain, right_wall), penalty_term=1000),
my_sim.method_interface = "nitsche" #penalty nitsche
my_sim.surface_to_volume = {
    inlet_boundary: fluid_subdomain,
    outlet_boundary: fluid_subdomain,
    inner_wall_boundary: left_wall,
    outer_wall_boundary: right_wall,
#define Species
H = F.Species("H")
my_sim.species = [H]
for species in my_sim.species:
    species.subdomains=[fluid_subdomain, left_wall,
                        right_wall
my_sim.define_meshtags_and_measures()
# define Conditions and settings
my_sim.temperature=800
my_sim.boundary_conditions= [
    F.FixedConcentrationBC(species=H,subdomain=inner_wall_boundary,value=1e20),
    F.FixedConcentrationBC(species=H,subdomain=outer_wall_boundary,value=0),
my_sim.settings = F.Settings(atol=1e10, rtol=1e-10, transient=False,max_iterations=500)
# run Simulation
my_sim.initialise()
my_sim.run()
## Post-process ##
def make_ugrid(solution):
    topology, cell_types, geometry = plot.vtk_mesh(solution.function_space)
    u_grid = pv.UnstructuredGrid(topology, cell_types, geometry)
    u_grid.point_data["c"] = solution.x.array.real
    u_grid.set_active_scalars("c")
    return u_grid
if isinstance(my_sim, F.HydrogenTransportProblemDiscontinuous):
    # plotting for HydrogenTransportProblemDiscontinuous
    pv.start_xvfb()
    #pv.set_jupyter_backend("html")
    u_plotter = pv.Plotter()
    u_grid_fluid = make_ugrid(H.subdomain_to_post_processing_solution[fluid_subdomain])
    u_grid_wall_l = make_ugrid(H.subdomain_to_post_processing_solution[left_wall])
    u_grid_wall_r = make_ugrid(H.subdomain_to_post_processing_solution[right_wall])
    u_plotter.add_mesh(u_grid_fluid, show_edges=False)
    u_plotter.add_mesh(u_grid_wall_l,show_edges=False)
    u_plotter.add_mesh(u_grid_wall_r,show_edges=False)
    u_plotter.view_xy()
    u_plotter.add_text("Hydrogen concentration in multi-material problem for Discontinuous", font_size=12)
    if not pv.OFF_SCREEN:
        u_plotter.show()
        figure = u_plotter.screenshot("concentration.png")
elif isinstance(my_sim, F.HydrogenTransportProblemDiscontinuousChangeVar):
    # plotting for HydrogenTransportProblemDiscontinuousChangeVar
    u_grid = make_ugrid(H.post_processing_solution)
    u_plotter.add_mesh(u_grid, show_edges=False)
    u_plotter.view_xy()
    u_plotter.add_text("Hydrogen concentration in multi-material problem for ChangeVar", font_size=12)
    u_plotter.show()
    raise TypeError(
        f"Unsupported FESTIM problem type: {type(my_sim)}"
# ChangeVar line profiles: concentration vs x[0] at multiple x[1]
from dolfinx import geometry
def eval_on_mesh(u, points):
    mesh = u.function_space.mesh
    gdim = mesh.geometry.dim
    pts = np.asarray(points, dtype=np.float64)
    if pts.ndim != 2 or pts.shape[1] != gdim:
        raise ValueError(f"points should be (N, {gdim})")
    # pad to 3D for dolfinx geometry/eval
    if gdim == 2:
        pts3 = np.zeros((pts.shape[0], 3), dtype=np.float64)
        pts3[:, :2] = pts
        pts3 = pts
    pts3 = np.ascontiguousarray(pts3)
    bb = geometry.bb_tree(mesh, mesh.topology.dim)
    candidates = geometry.compute_collisions_points(bb, pts3)
    colliding = geometry.compute_colliding_cells(mesh, candidates, pts3)
    npts = pts3.shape[0]
    cells = np.full(npts, -1, dtype=np.int32)
    if hasattr(colliding, "links"):
        for i in range(npts):
            links = colliding.links(i)
            if len(links):
                cells[i] = links[0]
    elif hasattr(colliding, "array") and hasattr(colliding, "offsets"):
        arr = colliding.array
        off = colliding.offsets
            start, end = off[i], off[i + 1]
            if end > start:
                cells[i] = arr[start]
        raise TypeError("Unsupported AdjacencyList type from dolfinx")
    values = np.full(len(pts), np.nan, dtype=float)
    mask = cells >= 0
    if np.any(mask):
        vals = u.eval(pts3[mask], cells[mask])
        values[mask] = vals.reshape(-1)
    return values
# ---- plotting ----
z_slices = [z_min + 0.02, z_min + 0.05, z_min + 0.08]
x0 = np.linspace(r_min - wall_l_thickness, r_max + wall_r_thickness, 600)
    # grab discontinuous concentration functions for each subdomain
    u_left  = H.subdomain_to_post_processing_solution[left_wall]
    u_fluid = H.subdomain_to_post_processing_solution[fluid_subdomain]
    u_right = H.subdomain_to_post_processing_solution[right_wall]
    fig, ax = plt.subplots(figsize=(7,4))
    for z in z_slices:
        y = np.full_like(x0, z, dtype=float)
        c = np.full_like(x0, np.nan, dtype=float)
        mask = x0 <= r_min
        c[mask] = eval_on_mesh(u_left, np.column_stack([x0[mask], y[mask]]))
        mask = (x0 >= r_min) & (x0 <= r_max)
        c[mask] = eval_on_mesh(u_fluid, np.column_stack([x0[mask], y[mask]]))
        mask = x0 >= r_max
        c[mask] = eval_on_mesh(u_right, np.column_stack([x0[mask], y[mask]]))
        ax.plot(x0, c, label=f"x[1]={z:.3g}")
    ax.axvline(r_min, color="k", lw=0.8, ls="--")
    ax.axvline(r_max, color="k", lw=0.8, ls="--")
    ax.set_xlabel("x[0]")
    #ax.set_yscale("log")
    ax.set_ylabel("Concentration")
    ax.set_title("Concentration profile across walls/fluid")
    ax.legend()
    # this is already concentration for ChangeVar
    u_c = H.post_processing_solution
    for z in z_slices:
        pts = np.column_stack([x0, y])
        c = eval_on_mesh(u_c, pts)
    ax.set_title("ChangeVar concentration profile")
    ax.legend()
    raise TypeError(
Best regards,
Chris
Hi Chris, thanks for reporting!
It seems to me that the penalty term isn’t large enough compared to the magnitude of the residual.
Consider using a penalty of say 1e20. You could also consider scaling the units of the problem to moles instead of atoms
Hey,
thanks for the answer!
Changing the penalty term made the sim converge and match the FESTIM1 benchmark, great!
My follow up question would be if there is any way to get an idea on how big the penalty value should be? I changed it before posting but I think the maximum value I tried was like 1e6.
You also mentioned that the penalty was small compared to the residual. Is there a way in FESTIM2 to actually look at or inspect the residual (similar to what was possible in FESTIM1 with log_level) and then take a decision on the penalty term?
Scalling to moles sounds interesting I will definitly check that out. The reason for doing so would be to decrease the magnitude of the values involved and thereby make the numerics easier. Is that correct?
Hey Remi,
after your initial suggestion worked, I increased the domain to a 5 body problem (Wall | Fluid | Wall | Fluid | Wall), which is closer to my target setup.
Changing the penalty (tested from 1 to 1e35) did not resolve the issue. With identical solubility laws across the domain the simulation converges, but the result looks physically incorrect (Eurofer and LiPb). With mixed solubility laws it does not converge at all (Eurofer and He_Purge).
Do you have any idea what could cause this?
I also experimented with scaling to moles but that didn’t help.
Below is a minimal working script. I reduced the problem to 1D.
import dolfinx
wall_id=3
axis_id=4
fluid_id=5
left_wall_id = 6
right_wall_id = 7
interface_l_id = 8
interface_r_id = 9
purge_id = 11
right_p_wall_id=12
wall_p_r_thickness =0.0025
r_max=0.02
z_max=0.1
nx=120
ny=200
r_min=0.005
z_min=0
height_pc =0.0025
n = 20
vertices = np.concatenate(
        np.linspace(0,r_min,num=n*2),
        np.linspace(r_min,r_max, num=n*6),
        np.linspace(r_max,r_max+wall_p_r_thickness,num=n),
        np.linspace(r_max+wall_p_r_thickness,r_max+wall_p_r_thickness+height_pc,num=n),
        np.linspace(r_max+wall_p_r_thickness+height_pc,r_max+wall_p_r_thickness+height_pc+wall_r_thickness,num=n*2)
mesh = F.Mesh1D(vertices=vertices)
inner_wall_boundary = F.SurfaceSubdomain1D(id=axis_id,x=0)
outer_wall_boundary = F.SurfaceSubdomain1D(id=wall_id, x = r_max + wall_p_r_thickness + height_pc + wall_r_thickness)
my_sim.mesh=mesh
S_0=9.0537131e19
D_0=8.83757e-06
He_Purge = F.Material(D_0=D_0, E_D=0, K_S_0=S_0, E_K_S=0,
PbLi = F.Material(
# Explicit x-locations of material interfaces (left -> right)
x_fluid_left = r_min
x_fluid_right = r_max
x_purge_wall_right = r_max + wall_p_r_thickness
x_purge_right = x_purge_wall_right + height_pc
left_wall = F.VolumeSubdomain1D(
    id=left_wall_id,
    material=Eurofer,#Dummy2 Eurofer
    borders=[0,x_fluid_left],
fluid_subdomain = F.VolumeSubdomain1D(
    id=fluid_id,
    material=He_Purge, #Dummy1 He_Purge PbLi
    borders= [x_fluid_left, x_fluid_right],
right_p_wall = F.VolumeSubdomain1D(
    id=right_p_wall_id,
    borders=[x_fluid_right, x_purge_wall_right]
purge_subdomain = F.VolumeSubdomain1D(
    id=purge_id,
    material=He_Purge, #Eurofer He_Purge Dummy1 PbLi
    borders=[x_purge_wall_right, x_purge_right]
right_wall = F.VolumeSubdomain1D(
    id=right_wall_id,
    borders=[x_purge_right, x_purge_right+wall_r_thickness],
    left_wall,
    fluid_subdomain,
    right_p_wall,
    purge_subdomain,
    right_wall,
pt = 1e20
    F.Interface(interface_l_id, (fluid_subdomain, left_wall),  penalty_term=pt),
    F.Interface(interface_r_id, (fluid_subdomain, right_p_wall), penalty_term=pt),
    F.Interface(99, (right_p_wall,purge_subdomain), penalty_term=pt),
    F.Interface(98,(purge_subdomain,right_wall),penalty_term=pt)
H = F.Species("H")
H.subdomains = [fluid_subdomain, left_wall, right_p_wall, purge_subdomain,right_wall]
my_sim.temperature = 800
my_sim.boundary_conditions = [
    F.FixedConcentrationBC(species=H, subdomain=inner_wall_boundary, value=1e20),
    F.FixedConcentrationBC(species=H, subdomain=outer_wall_boundary, value=0),
    atol=1e10,
    rtol=1e-8,
    max_iterations=600,
my_sim.initialise()
my_sim.run()
plot_domains = [
    (left_wall, "left_wall"),
    (fluid_subdomain, "fluid"),
    (right_p_wall, "right_p_wall"),
    (purge_subdomain, "purge"),
    (right_wall,"right_wall")
plt.figure(figsize=(9, 4))
for volume, label in plot_domains:
    u = H.subdomain_to_post_processing_solution[volume]
    x = u.function_space.tabulate_dof_coordinates()[:, 0]
    c = u.x.array.real.copy()
    order = np.argsort(x)
    plt.plot(x[order], c[order], label=label)
for x_interface in [x_fluid_left, x_fluid_right, x_purge_wall_right]:
    plt.axvline(x_interface, color="k", linestyle="--", linewidth=0.8)
plt.xlabel("x [m]")
plt.ylabel("H concentration")
plt.title("1D discontinuous solution")
plt.tight_layout()
Best,
Chris
I’m not sure simualting the He purge like this is the way to go. Plus, if you’re mixing solubility laws, you should use the "penalty" interface method and not the default “nitsche”.
@ChrisSo we moved the discussion to this issue
