Issue with checkpoints
Hello everybody !
I’m running a simulation and I want to get data at certain time, so I tried using checkpoints.
Getting to high duration, I felt like my simulation was starting over everytime instead of starting from the checkpoint.
Here is a simplified version of my code :
import basix
import ufl
import numpy.typing as npt
import scipy as scp
import adios4dolfinx
import sys
import dolfinx
from dolfinx import fem
from dolfinx.io import VTXWriter
assert MPI.COMM_WORLD.size == 1
temps = [1.5, 3, 4.5, 6]
data_dir = "data_simu_test/"
for i in range(len(temps)):
    model = F.HydrogenTransportProblem()
    n = 1000
    vertice = []
    L = 10e-5
    vertice = np.concatenate(
            np.linspace(0, 100e-9, num=100, endpoint=False),
            np.linspace(1e-7, 1e-5, num=198, endpoint=False),
            np.linspace(1e-5, L, num=200),
    model.mesh = F.Mesh1D(vertice)
    difW = 1.9e-7
    E_diff = 0.2
    tungst = F.Material(name="W", D_0=difW, E_D=E_diff)
    vol = F.VolumeSubdomain1D(id=1, borders=[0, L], material=tungst)
    surf_left = F.SurfaceSubdomain1D(id=1, x=0)
    surf_right = F.SurfaceSubdomain1D(id=2, x=L)
    W_atom_density = 19.25e3 / (
        183.84 * 1.66e-27
    model.subdomains = [vol, surf_left, surf_right]
    mobile_H = F.Species("H")
    mobile_D = F.Species("D")
    trapH = F.Species("trapH", mobile=False)
    trapD = F.Species("trapD", mobile=False)
    def density_trap1(mod=np) : return lambda x: 0.002 * W_atom_density
    density_trap1_ufl = density_trap1(mod=ufl)
    trapA = F.ImplicitSpecies(n=density_trap1_ufl, others=[trapD, trapH], name="trapA")
    model.species = [
        mobile_D,
        mobile_H,
        trapD,
        trapH,
    if i != 0:
        #if it's not the first iteration of the loop, use the checkpoint to start from where the previous simulation ended
        model.initial_conditions = [
            F.InitialCondition(
                value=F.read_function_from_file(
                    filename=data_dir + "checkpoint.bp",
                    name="H",
                    timestamp=temps[i-1]*3600,
                species=mobile_H,
            F.InitialCondition(
                    name="D",
                species=mobile_D,
    model.reactions = [
        F.Reaction(  # trap A D
            k_0=1e13 / (6*W_atom_density),
            E_k=E_diff,
            E_p=1.5,
            reactant=[mobile_D, trapA],
            product=trapD,
            volume=vol,
        F.Reaction(  # trap A H
            k_0=1e13 / W_atom_density,
            E_k=E_diff,
            E_p=1.5,
            reactant=[mobile_H, trapA],
            product=trapH,
            volume=vol,
        F.DirichletBC(subdomain=surf_left, value=2e16, species=mobile_D),
        F.DirichletBC(subdomain=surf_left, value=5e16, species=mobile_H),
        F.DirichletBC(subdomain=surf_right, value=0, species=mobile_D),
        F.DirichletBC(subdomain=surf_right, value=0, species=mobile_H),
    model.temperature = 600
    invent_mobD = F.TotalVolume(field=mobile_D, volume=vol)
    invent_trapAD = F.TotalVolume(field=trapD, volume=vol)
    checkpoint1 = F.VTXSpeciesExport(filename=data_dir+"checkpoint.bp", field=[
        mobile_D,
        mobile_H], checkpoint=True )
    model.exports = [
        invent_mobD,
        invent_trapAD,
        checkpoint1,
    phase_s=temps[i]*3600
    model.settings = F.Settings(atol=1e8, rtol=1e-12, max_iterations=500, final_time=phase_s)
    model.settings.stepsize = F.Stepsize(
        initial_value=0.5,
        growth_factor=1.05,
        target_nb_iterations=20,
        cutback_factor=0.95,
        max_stepsize=100,
    model.settings.stepsize.milestones= [phase_s*0.5, phase_s*0.75, phase_s*0.95, phase_s]
    np.savetxt(data_dir+"trap_D_"+str(temps[i])+".txt", np.array(trapD.post_processing_solution.x.array))
When running the code, I get the following in the terminal :
4_checkpoints
If I understand well, we can see the 4 step getting increasingly longer (5.4k, 10.8k, 16.2k and 21.6k) where (if I understood well) they should all be of the same length (all four being 1.5h simulated).
Thank you in advance for your help, hope it’s not just me getting everything wrong with checkpoints.
what version of FESTIM are you using?
I am using the fenicsx branch and I am up to date with all the recent changes.
Here’s a MWE running on v2.0-alpha-4
    L = 10e-5
    model.mesh = F.Mesh1D(np.linspace(0, L, num=200))
    tungst = F.Material(name="W", D_0=1, E_D=0)
    model.species = [mobile_D, mobile_H]
    if i != 0:
        # if it's not the first iteration of the loop, use the checkpoint to start from where the previous simulation ended
            F.InitialCondition(
                    name="H",
                    timestamp=temps[i - 1] * 3600,
                species=mobile_H,
            F.InitialCondition(
                    name="D",
                species=mobile_D,
        filename=data_dir + "checkpoint.bp", field=[mobile_D, mobile_H], checkpoint=True
    model.exports = [checkpoint1]
    phase_s = temps[i] * 3600
    model.settings = F.Settings(atol=1e8, rtol=1e-12, final_time=phase_s)
    model.settings.stepsize = F.Stepsize(initial_value=100)
    model.settings.stepsize.milestones = [
        phase_s * 0.5,
        phase_s * 0.75,
        phase_s * 0.95,
        phase_s,
    print(f"Running simulation for time: {temps[i]} hours")
    print(f"Initial time: {float(model.t)} s")
    print(f"Final time: {float(model.settings.final_time)} s")
Produces:
Running simulation for time: 1.5 hours
Initial time: 0.0 s
Final time: 5400.0 s
Solving HydrogenTransportProblem: 100%|β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 5.40k/5.40k [00:00<00:00, 96.8kit/s]
Running simulation for time: 3 hours
Initial time: 0.0 s
Final time: 10800.0 s
Solving HydrogenTransportProblem: 100%|β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 10.8k/10.8k [00:00<00:00, 90.5kit/s]
Running simulation for time: 4.5 hours
Initial time: 0.0 s
Final time: 16200.0 s
Solving HydrogenTransportProblem: 100%|β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 16.2k/16.2k [00:00<00:00, 107kit/s]
Running simulation for time: 6 hours
Initial time: 0.0 s
Final time: 21600.0 s
Solving HydrogenTransportProblem: 100%|β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 21.6k/21.6k [00:00<00:00, 109kit/s]
The β€œissue” here is that by default, the starting time of a new model is t=0. You are just telling FESTIM β€œuse this timestamp from this other VTX file as an initial condition for t=0”. Therefore the simulated time increases.
This means there are two solutions to your issue:
  1. simply accept that simulation times are relative and handle that in post-process. Set the final simulation time to a fixed number
  2. after initialise() change the value of model.t. This isn’t ideal as it messes up the progress bar (minor) and could potentially mess with any time dependent boundary condition, source, etc (major).
model.t.value = temps[i - 1] * 3600 if i != 0 else 0
Okay thank you very much for the help and the explanation.
I will go back to my code and adapt what nedd to be and get what I’m looking for.
Hello again, I solved my previous issue with the time of simulation, but I’ve realized that when I try to add the trapH or trapD species in the field argument of the checkpoint, the first simulation using a checkpoint encounters an error and stops immediatley with teh following message :
File "/Home/JD270099/.conda/envs/hisp-env/lib/python3.13/site-packages/adios4dolfinx/checkpointing.py", line 358, in read_function
dof_owner = index_owner(comm, input_dofmap.array, num_dofs_global)
File "/Home/JD270099/.conda/envs/hisp-env/lib/python3.13/site-packages/adios4dolfinx/utils.py", line 127, in index_owner
assert (indices < N).all()
AssertionError
Is there a specific way to use the checkpoints with non-mobile species ?
Thanks in advance for your answers !
@JonathanGSDUFOUR can you produce a MWE reproducing the error you shared please?
Here is the code which gives the error. If I remove tradH and trapD from the checkpoint and the InitialCondition everything is working correctly.
import basix
import ufl
import scipy as scp
import sys
import dolfinx
temps = [2, 4, 7 ,10, 15]
duree = 0
duree_prec = 0
    duree_prec = duree
    if i == 0:
        duree= temps[i]*3600
        duree=(temps[i]-temps[i-1])*3600
    n = 1000
    vertice = []
    L = 10e-5
    print("duree is"+str(duree))
    print("duree_prec is"+str(duree_prec))
        183.84 * 1.66e-27
    model.species = [
        mobile_D,
        mobile_H,
        trapD,
        trapH,
    if i != 0:
            F.InitialCondition(
                    name="H",
                    timestamp=duree_prec,
                species=mobile_H,
            F.InitialCondition(
                    name="D",
                species=trapH,
            F.InitialCondition(
                    name="trapD",
                species=trapD,
            F.InitialCondition(
                    name="trapH",
                species=trapH,
    model.reactions = [
        F.Reaction(
            E_k=1,
            E_p=1.5,
            product=trapD,
            volume=vol,
        F.Reaction(
            E_k=1,
            E_p=1.5,
            product=trapH,
            volume=vol,
        mobile_D,
        mobile_H,
        trapD,
        trapH
    model.exports = [
        checkpoint1,
    model.settings = F.Settings(atol=1e8, rtol=1e-12, max_iterations=500, final_time=duree)
        initial_value=0.5,
        growth_factor=1.05,
        max_stepsize=100,
    if i!= 0:
       print(temps[i-1]*3600)
       print(duree_prec)
       print(duree)
    model.settings.stepsize.milestones= [duree*0.5, duree*0.75, duree*0.95, duree]
    np.savetxt(data_dir+"time_trap"+str(temps[i])+".txt", np.array(invent_trapAD.t))
    np.savetxt(data_dir+"invent_D"+str(temps[i])+".txt", invent_trapAD.data)
@JonathanGSDUFOUR this is not really a MWE and can be quite hard to parse:
  • most of the imports are not needed
  • the reactions are not needed
  • the BCs are not needed
  • the last np.savetxt calls are not needed
  • the TotalVolume isn’t needed
Here’s a MWE that reproduces your issue:
model.mesh = F.Mesh1D(np.linspace(0, 1, num=200))
vol = F.VolumeSubdomain1D(id=1, borders=[0, 1], material=tungst)
surf_right = F.SurfaceSubdomain1D(id=2, x=1)
model.species = [mobile_H, trapH]
model.settings = F.Settings(atol=1e8, rtol=1e-12, final_time=100)
model.settings.stepsize = F.Stepsize(10)
model.exports = [
    F.VTXSpeciesExport(
        filename="checkpoint.bp",
        field=[mobile_H, trapH],
        checkpoint=True,
# try and read the file
c_H_in = F.read_function_from_file(
    name="H",
    timestamp=100,
c_H_trap_in = F.read_function_from_file(
    name="trapH",
    timestamp=100,
45 lines vs 172 :wink:
The issue is that in FESTIM, by default (in fact it’s hard coded), immobile species are defined on a DG1 functionspace and not a CG1 functionspace like mobile ones.
The read_function_from_file has a family argument that defaults to "P" (ie. CG).
To make your code work, simply change it to "DG":
    name="trapH",
    timestamp=100,
    family="DG",
