Grain-level 2D multi-material interface
Hi All,
I am having an issue running a multi-material simulation in 2D. The model represents a square grain of ceramic (Li2TiO3) with a narrower grain adjacent to it that mimics an ‘amorphous’ layer. This layer has different material properties to the ceramic grain.
The tritium diffuses through the bulk, but when it reaches the interface with the amorphous layer it does not enter it. I wonder if it is an issue with the way I assign the F.Interface class?
Here is the code with a fig to illustrate:
import gmsh
from dolfinx.io import gmshio
if not os.path.exists('results'):
    os.makedirs('results')
hydrogen_problem = F.HydrogenTransportProblem()
width_bulk = 10e-6  # 5 micrometers
width_amorphous = 3e-6  # 3 micrometers
def create_two_region_mesh():
    Create mesh using gmsh for better control over interfaces
    grain_size = width_bulk
    gb_width = width_amorphous
    gmsh.initialize()
    gmsh.model.add("two_regions")
    # Create points
    p1 = gmsh.model.geo.addPoint(0, 0, 0)
    p2 = gmsh.model.geo.addPoint(grain_size, 0, 0)
    p3 = gmsh.model.geo.addPoint(grain_size, grain_size, 0)
    p4 = gmsh.model.geo.addPoint(0, grain_size, 0)
    p5 = gmsh.model.geo.addPoint(grain_size + gb_width, 0, 0)
    p6 = gmsh.model.geo.addPoint(grain_size + gb_width, grain_size, 0)
    # Create lines for grain region
    l1 = gmsh.model.geo.addLine(p1, p2)
    l2 = gmsh.model.geo.addLine(p2, p3)
    l3 = gmsh.model.geo.addLine(p3, p4)
    l4 = gmsh.model.geo.addLine(p4, p1)
    # Create lines for grain boundary region
    l5 = gmsh.model.geo.addLine(p2, p5)
    l6 = gmsh.model.geo.addLine(p5, p6)
    l7 = gmsh.model.geo.addLine(p6, p3)
    # Create curve loops
    grain_loop = gmsh.model.geo.addCurveLoop([l1, l2, l3, l4])
    gb_loop = gmsh.model.geo.addCurveLoop([l5, l6, l7, -l2])
    # Create surfaces
    grain_surface = gmsh.model.geo.addPlaneSurface([grain_loop])
    gb_surface = gmsh.model.geo.addPlaneSurface([gb_loop])
    # Set mesh sizes
    gmsh.model.geo.mesh.setSize([(0, p1), (0, p2), (0, p3), (0, p4)], grain_size/ 200)  # Fine in grain
    gmsh.model.geo.mesh.setSize([(0, p5), (0, p6)], gb_width/ 200)  # Finer in GB
    # Physical groups
    gmsh.model.addPhysicalGroup(2, [grain_surface], 1)
    gmsh.model.setPhysicalName(2, 1, "grain")
    gmsh.model.addPhysicalGroup(2, [gb_surface], 2)
    gmsh.model.setPhysicalName(2, 2, "grain_boundary")
    # Boundaries
    gmsh.model.addPhysicalGroup(1, [l4], 3)  # left boundary
    gmsh.model.setPhysicalName(1, 3, "left")
    gmsh.model.addPhysicalGroup(1, [l6], 4)  # right boundary
    gmsh.model.setPhysicalName(1, 4, "right")
    gmsh.model.addPhysicalGroup(1, [l3, l7], 5)  # top boundary
    gmsh.model.setPhysicalName(1, 5, "top")
    gmsh.model.addPhysicalGroup(1, [l1, l5], 6)  # bottom boundary
    gmsh.model.setPhysicalName(1, 6, "bottom")
    gmsh.model.addPhysicalGroup(1, [l2], 7)  # interface
    gmsh.model.setPhysicalName(1, 7, "interface")
    gmsh.model.geo.synchronize()
    gmsh.model.mesh.generate(2)
    # Convert to dolfinx mesh
    mesh_2d, cell_tags, facet_tags = gmshio.model_to_mesh(
        gmsh.model, MPI.COMM_WORLD, 0, gdim=2
    gmsh.finalize()
    total_width = grain_size + gb_width
    print(f"✓ GMSH two-region mesh created!")
    print(f"  - Total dimensions: {total_width*1e6:.1f} μm × {grain_size*1e6:.1f} μm")
    return mesh_2d, total_width, grain_size, gb_width, cell_tags, facet_tags
# Update region locators for the new geometry
def bulk_grain_locator(x):
    """Square grain region (left side)"""
    return x[0] < grain_size
def grain_boundary_locator(x):
    """Rectangle grain boundary region (right side)"""
    return x[0] >= grain_size
# Update boundary locators for new geometry
def left_boundary_locator(x):
    """Left edge of square grain"""
    return np.isclose(x[0], 0, atol=1e-12)
def right_boundary_locator(x):
    """Right edge of grain boundary"""
    return np.isclose(x[0], grain_size + gb_width, atol=1e-12)
def top_boundary_locator(x):
    """Top edge (both regions)"""
    return np.isclose(x[1], grain_size, atol=1e-12)
def bottom_boundary_locator(x):
    """Bottom edge (both regions)"""
    return np.isclose(x[1], 0, atol=1e-12)
def gb_interface_locator(x):
    """Interface between square grain and grain boundary"""
    return np.isclose(x[0], grain_size, atol=1e-12)
mesh_2d, total_width, grain_size, gb_width, cell_tags, facet_tags = create_two_region_mesh()
festim_mesh = F.Mesh(mesh_2d)
hydrogen_problem.mesh = festim_mesh
# Update materials (same as before)
bulk_material = F.Material(
    name="LiTiO3",
    D_0=9.5E-6,
    E_D=0.80,
    thermal_conductivity=2.5,
    density=2881,
    heat_capacity=1600
gb_material = F.Material(
    name="LiTiO3_amorphous",
    D_0=9.3e-7,
    E_D=0.41,
    density=2881,
    heat_capacity=1600
# Volume subdomains for two regions
vol_bulk_grain = F.VolumeSubdomain(id=1, material=bulk_material, locator=bulk_grain_locator)
vol_grain_boundary = F.VolumeSubdomain(id=2, material=gb_material, locator=grain_boundary_locator)
# Surface subdomains (external boundaries only)
surf_left = F.SurfaceSubdomain(id=3, locator=left_boundary_locator)
surf_right = F.SurfaceSubdomain(id=4, locator=right_boundary_locator)
surf_top = F.SurfaceSubdomain(id=5, locator=top_boundary_locator)
surf_bottom = F.SurfaceSubdomain(id=6, locator=bottom_boundary_locator)
# Updated subdomains list
hydrogen_problem.subdomains = [
    vol_bulk_grain,
    vol_grain_boundary,
    surf_left,
    surf_right,
    surf_top,
    surf_bottom
# Interface between bulk grain and grain boundary
interface_gb = F.Interface(
    id=7,
    subdomains=[vol_bulk_grain, vol_grain_boundary],
    penalty_term=1e25
hydrogen_problem.interfaces = [interface_gb]
hydrogen_problem.surface_to_volume = {
    surf_left: vol_bulk_grain,
    surf_right: vol_grain_boundary
# Species in both regions
mobile_T = F.Species("T", subdomains=[vol_bulk_grain, vol_grain_boundary])
hydrogen_problem.species = [mobile_T]
# Boundary conditions - source from left surface
boundary_left = F.FixedConcentrationBC(
    subdomain=surf_left, species=mobile_T, value=1e15
hydrogen_problem.boundary_conditions = [boundary_left]
final_time = 100.0 # seconds
# Initial conditions
temperature = 700  # K
hydrogen_problem.temperature = temperature
hydrogen_problem.settings = F.Settings(
    atol=1e10,
    rtol=1e-10,
    final_time=final_time,
    transient=True,
    max_iterations=10000
hydrogen_problem.settings.stepsize = F.Stepsize(1)  # 1 second time step
print("Creating tritium transport problem")
# Exports for hydrogen problem
hydrogen_problem.exports = [
    F.VTXSpeciesExport(
        filename="results/2D/grain_level/tritium_transport/grain_tritium.bp",
        field=mobile_T,
        checkpoint=True,
    F.XDMFExport(
        filename="results/2D/grain_level/tritium_transport/grain_tritium.xdmf",
        field=[mobile_T]
print("Individual problem exports configured")
# Run the grain problem
print("Initializing hydrogen transport simulation in 1D grains")
hydrogen_problem.initialise()
print("Running simulation...")
hydrogen_problem.run()
print("Simulation completed!")
def plot_one_grain_results():
    Plot results for single grain + amorphous layer geometry
    try:
        concentration_field = F.read_function_from_file(
            name="T",
            timestamp=final_time
        V = concentration_field.function_space
        coords = V.tabulate_dof_coordinates()
        x_coords = coords[:, 0]
        y_coords = coords[:, 1]
        conc_values = concentration_field.x.array
        fig, ax = plt.subplots(1, 1, figsize=(10, 8))
        scatter = ax.scatter(x_coords*1e6, y_coords*1e6, c=conc_values,
                            cmap='viridis', s=15, alpha=0.8)
        ax.set_title('Tritium Concentration: Grain → Amorphous Layer', fontsize=14)
        ax.set_xlabel('X Position (μm)')
        ax.set_ylabel('Y Position (μm)')
        ax.axvline(x=grain_size*1e6, color='red', linestyle='--', alpha=0.7,
                   linewidth=2, label='Grain-Amorphous Interface')
        ax.legend()
        ax.set_aspect('equal')
        ax.grid(True, alpha=0.3)
        plt.colorbar(scatter, ax=ax, label='Concentration (atoms/m³)')
        plt.tight_layout()
        plt.savefig('results/2D/grain_level/one_grain_results.png', dpi=300, bbox_inches='tight')
        print(f"\n=== RESULTS ===")
        print(f"Mobile tritium concentration range: {np.min(conc_values):.2e} to {np.max(conc_values):.2e} atoms/m³")
        print(f"Amorphous Layer width: {gb_width*1e6:.1f} μm")
        print(f"Total width: {total_width*1e6:.1f} μm")
    except Exception as e:
        print(f"Error in plotting: {e}")
fyi I tried it in 1D first and it works:
width_amorphous = 1e-6  # 0.9 micrometers
vertices = np.concatenate(
        np.linspace(0, width_bulk, num=600),
        np.linspace(width_bulk, (width_bulk + width_amorphous), num=600)
# Create the two-grain mesh
my_mesh = F.Mesh1D(vertices=vertices)
hydrogen_problem.mesh = my_mesh
    name="LiTiO3",
    D_0=9.5E-6,               # Diffusion pre-exponential factor [m²/s] 9.5E-6
    E_D=0.80,                 # Activation energy [eV] 0.80
    thermal_conductivity=2.5,  # Thermal conductivity
    density=2881,              # Density [kg/m³]
    heat_capacity=1600         # Heat capacity [J/kg/K]
    D_0=9.3e-7,
    E_D=0.41,
    density=2881,
    heat_capacity=1600
vol_left_grain = F.VolumeSubdomain1D(id=1, material=bulk_material, borders=[0, width_bulk])
vol_amorphous_layer = F.VolumeSubdomain1D(id=2, material=gb_material, borders=[width_bulk, (width_bulk + width_amorphous)])
left_surface = F.SurfaceSubdomain1D(id=3, x=0)
right_surface = F.SurfaceSubdomain1D(id=4, x=(width_bulk + width_amorphous))
    vol_left_grain,
    vol_amorphous_layer,
    left_surface,
    right_surface,
bulk_gb_interface = F.Interface(
    id=5,
    subdomains=[vol_left_grain, vol_amorphous_layer],
    penalty_term=1e25
hydrogen_problem.interfaces = [bulk_gb_interface]
    left_surface : vol_left_grain,
    right_surface : vol_amorphous_layer
mobile_T = F.Species("T", subdomains=[vol_left_grain, vol_amorphous_layer])
        subdomain=left_surface, species=mobile_T, value=1e15
hydrogen_problem.temperature = 700  # K
    transient=True,
    atol=1e10,
    rtol=1e-10,
    final_time=200,
    stepsize=1,
    F.VTXSpeciesExport(
        filename="results/1D/grain_level/tritium_transport/bulk_tritium.bp",
        field=[mobile_T],
    F.XDMFExport(
        filename="results/1D/grain_level/tritium_transport/grain_tritium.xdmf",
        field=[mobile_T],
I have also tried these other trouble shooting methods:
  • a single rectangluar dolfinx mesh that is split into two regions.
  • refining the mesh into the amorphous region
  • using a tritium source term for the bulk instead of a fixed concentration bc on the left surface
Thank you in advance for your help!
Hi @griff,
This is a meshing/tagging issue.
If you plot the meshtags with:
import pyvista
from dolfinx import plot
mesh = hydrogen_problem.mesh.mesh
ft = hydrogen_problem.facet_meshtags
ct = hydrogen_problem.volume_meshtags
fdim = mesh.topology.dim - 1
tdim = mesh.topology.dim
mesh.topology.create_connectivity(fdim, tdim)
topology, cell_types, x = plot.vtk_mesh(mesh, tdim, ct.indices)
p = pyvista.Plotter()
grid = pyvista.UnstructuredGrid(topology, cell_types, x)
grid.cell_data["Cell Marker"] = ct.values
grid.set_active_scalars("Cell Marker")
p.add_mesh(grid, show_edges=False)
if pyvista.OFF_SCREEN:
    figure = p.screenshot("cell_marker.png")
p.show()
You will see that some cells are tagged with 0. This is because your locators aren’t defined properly.
How to fix this:
  1. add some tolerances to your locators:
    return x[0] < grain_size + 1e-12
    return x[0] >= grain_size - 1e-12
  1. Since you use GMSH and generate tags, you can directly pass them to your problem and not define locators in VolumeSubdomain and SurfaceSubdomain:
vol_bulk_grain = F.VolumeSubdomain(id=1, material=bulk_material)
vol_grain_boundary = F.VolumeSubdomain(id=2, material=gb_material)
surf_left = F.SurfaceSubdomain(id=3)
surf_right = F.SurfaceSubdomain(id=4)
surf_top = F.SurfaceSubdomain(id=5)
surf_bottom = F.SurfaceSubdomain(id=6)
hydrogen_problem.facet_meshtags = facet_tags
hydrogen_problem.volume_meshtags = cell_tags
Note:
  • If you want to impose a concentration discontinuity at the interface, then you should use F.HydrogenTransportProblemDiscontinuous and not F.HydrogenTransportProblem
  • If you don’t want to use Paraview, I would recommend using pyvista to plot your fields in python.
import pyvista
    mobile_T.post_processing_solution.function_space
grid.point_data["C"] = mobile_T.post_processing_solution.x.array.real
grid.set_active_scalars("C")
    figure = p.screenshot("c.png")
p.show()
Problem solved, thank you!
