I am working with three different materials — tungsten, EUROFER, and FLiBe — in a 2D geometry. I previously used FESTIM 1, but I was getting numerical errors, so I decided to move to FESTIM 2.
When running a transient simulation with:
my_model = F.HydrogenTransportProblem()
I obtain reasonable results for the mobile concentration, but I am not able to export the trapped tritium fields, neither with F.VTXSpeciesExport nor with F.XDMFExport (I am using DG and not CG). I would like to visualise the trapped concentrations to verify whether the numerical issues disappear in FESTIM 2.
I am attaching my mesh files in case you want to reproduce the issue:
mesh_domains.h5 (163.2 KB)
mesh_domains.xdmf (584 Bytes)
mesh_boundaries.h5 (101.5 KB)
mesh_boundaries.xdmf (587 Bytes)
The input data should be correct, as the corresponding 1D model works fine.
Below I include the full script I am using (sorry for the length, but I wanted to provide all details).
import meshio
#import matplotlib.pyplot as plt
import copy
from dolfinx import plot
flag=1 # 1 per quad, 0 per triangoli
folder = "/home/andre/miniconda3/TESI/Pure_Diff/"
results_folder = "/home/andre/miniconda3/TESI/Pure_Diff_traps/"
#my_model = F.HydrogenTransportProblemDiscontinuous()
if flag==1:
mesh = F.MeshFromXDMF(folder +"quad/mesh_domains.xdmf", folder + "quad/mesh_boundaries.xdmf")
mesh = F.MeshFromXDMF(folder +"tria/mesh_domains.xdmf", folder + "tria/mesh_boundaries.xdmf")
my_model.mesh = mesh
tungsten_mat = F.Material(
D_0=4.1e-7/(np.sqrt(3)),
E_D=0.39,
K_S_0=1.35e22,
E_K_S=0.29,
euro_fer_mat = F.Material(
D_0=1.07e-6/(np.sqrt(3)),
E_D=0.51,
K_S_0=1.35e22,
E_K_S=0.16,
FLiBe_mat = F.Material(
D_0=9.3e-7,
E_D=42.5/96.48,
K_S_0=(7.9e-2)*(6.022e23),
E_K_S=35/96.48,
tungsten = F.VolumeSubdomain(id=8, material=tungsten_mat)
euro_fer = F.VolumeSubdomain(id=9, material=euro_fer_mat)
FLiBe = F.VolumeSubdomain(id=10, material=FLiBe_mat)
inlet_surf=F.SurfaceSubdomain(id=6, )
dirichelt_surf=F.SurfaceSubdomain(id=7)
neumann_surf=F.SurfaceSubdomain(id=12)
my_model.subdomains = [tungsten, euro_fer, FLiBe, inlet_surf, dirichelt_surf, neumann_surf]
my_model.surface_to_volume = {
inlet_surf: tungsten, # o quel volume che tocca l’inlet
dirichelt_surf: FLiBe, # quel volume che tocca Dirichlet
neumann_surf: FLiBe, # o altro volume che tocca Neumann
# Interfaces
my_model.interfaces = [
F.Interface(id=11, subdomains=[euro_fer, FLiBe], penalty_term=1e10),
F.Interface(id=13, subdomains=[tungsten, euro_fer], penalty_term=1e10),
import ufl
x = ufl.SpatialCoordinate(my_model.mesh.mesh) # coord x del dominio
m1 = (1240 - 1300) / 0.01 # tra 0 e 0.01
m2 = (850 - 1240) / 0.03 # tra 0.01 e 0.04
T_expr = ufl.conditional(
ufl.le(x[0], 0.01),
1300.0 + m1 * x[0],
ufl.conditional(
ufl.le(x[0], 0.04),
1240.1 + m2 * (x[0] - 0.01),
850,
my_model.temperature = lambda x: T_expr
mobile_T = F.Species("T", subdomains=[tungsten, euro_fer, FLiBe], mobile=True)
trapped_T_1 = F.Species("T_trapped_1", mobile=False, subdomains=[tungsten])
trapped_T_2 = F.Species("T_trapped_2", mobile=False, subdomains=[tungsten])
trapped_T_3 = F.Species("T_trapped_3", mobile=False, subdomains=[tungsten])
trapped_T_4= F.Species("T_trapped_4", mobile=False, subdomains=[tungsten])
trapped_T_5 = F.Species("T_trapped_5", mobile=False, subdomains=[tungsten])
trapped_T_6 = F.Species("T_trapped_6", mobile=False, subdomains=[tungsten])
trapped_T_7 = F.Species("T_trapped_7", mobile=False, subdomains=[euro_fer])
trapped_T_8 = F.Species("T_trapped_8", mobile=False, subdomains=[euro_fer])
trapped_T_9 = F.Species("T_trapped_9", mobile=False, subdomains=[euro_fer])
trapped_T_10 = F.Species("T_trapped_10", mobile=False, subdomains=[euro_fer])
trapped_T_11 = F.Species("T_trapped_11", mobile=False, subdomains=[euro_fer])
empty_traps_1 = F.Species("empty_traps_1", mobile=False, subdomains=[tungsten])
empty_traps_2 = F.Species("empty_traps_2", mobile=False, subdomains=[tungsten])
empty_traps_3 = F.Species("empty_traps_3", mobile=False, subdomains=[tungsten])
empty_traps_4 = F.Species("empty_traps_4", mobile=False, subdomains=[tungsten])
empty_traps_5 = F.Species("empty_traps_5", mobile=False, subdomains=[tungsten])
empty_traps_6 = F.Species("empty_traps_6", mobile=False, subdomains=[tungsten])
empty_traps_7 = F.Species("empty_traps_7", mobile=False, subdomains=[euro_fer])
empty_traps_8 = F.Species("empty_traps_8", mobile=False, subdomains=[euro_fer])
empty_traps_9 = F.Species("empty_traps_9", mobile=False, subdomains=[euro_fer])
empty_traps_10 = F.Species("empty_traps_10", mobile=False, subdomains=[euro_fer])
empty_traps_11 = F.Species("empty_traps_11", mobile=False, subdomains=[euro_fer])
#my_model.species = [mobile_T]
my_model.species = [mobile_T, trapped_T_1,empty_traps_1,trapped_T_2, empty_traps_2, trapped_T_3, empty_traps_3, trapped_T_4, empty_traps_4, trapped_T_5, empty_traps_5, trapped_T_6, empty_traps_6, trapped_T_7, empty_traps_7, trapped_T_8, empty_traps_8, trapped_T_9, empty_traps_9, trapped_T_10, empty_traps_10, trapped_T_11, empty_traps_11]
w_atom_density = 6.3e28 # atom/m3
euro_atom_density = 7.8e3*6.022e23/(57.2*1e-3) # atom/m3
my_model.initial_conditions = [
F.InitialConcentration(value=0.0, species=mobile_T, volume=tungsten),
F.InitialConcentration(value=0.0, species=mobile_T, volume=euro_fer),
F.InitialConcentration(value=0.0, species=mobile_T, volume=FLiBe),
F.InitialConcentration(value=2.4e22, species=empty_traps_1, volume=tungsten),
F.InitialConcentration(value=6.9e25, species=empty_traps_2, volume=tungsten),
F.InitialConcentration(value=7e25, species=empty_traps_3, volume=tungsten),
F.InitialConcentration(value=6e25, species=empty_traps_4, volume=tungsten),
F.InitialConcentration(value=4.7e25, species=empty_traps_5, volume=tungsten),
F.InitialConcentration(value=2e25, species=empty_traps_6, volume=tungsten),
F.InitialConcentration(value=6.9e25, species=empty_traps_7, volume=euro_fer),
F.InitialConcentration(value=7e25, species=empty_traps_8, volume=euro_fer),
F.InitialConcentration(value=6e25, species=empty_traps_9, volume=euro_fer),
F.InitialConcentration(value=4.7e25, species=empty_traps_10, volume=euro_fer),
F.InitialConcentration(value=2e25, species=empty_traps_11, volume=euro_fer),
F.InitialConcentration(value=0, species=trapped_T_1, volume=tungsten),
F.InitialConcentration(value=0, species=trapped_T_2, volume=tungsten),
F.InitialConcentration(value=0, species=trapped_T_3, volume=tungsten),
F.InitialConcentration(value=0, species=trapped_T_4, volume=tungsten),
F.InitialConcentration(value=0, species=trapped_T_5, volume=tungsten),
F.InitialConcentration(value=0, species=trapped_T_6, volume=tungsten),
F.InitialConcentration(value=0, species=trapped_T_7, volume=euro_fer),
F.InitialConcentration(value=0, species=trapped_T_8, volume=euro_fer),
F.InitialConcentration(value=0, species=trapped_T_9, volume=euro_fer),
F.InitialConcentration(value=0, species=trapped_T_10, volume=euro_fer),
F.InitialConcentration(value=0, species=trapped_T_11, volume=euro_fer),
my_model.reactions = [
F.Reaction(
reactant=[mobile_T, empty_traps_1],
product=[trapped_T_1],
k_0=4.1e-7/(1.1e-10**2*6*w_atom_density),
E_k=0.28,
p_0=1.13,
E_p=1.04,
volume=tungsten,
F.Reaction(
reactant=[mobile_T, empty_traps_2],
product=[trapped_T_2],
E_k=0.39,
p_0=1.13,
E_p=1.15,
volume=tungsten,
F.Reaction(
reactant=[mobile_T, empty_traps_3],
product=[trapped_T_3],
E_k=0.39,
p_0=1.13,
E_p=1.35,
volume=tungsten,
F.Reaction(
reactant=[mobile_T, empty_traps_4],
product=[trapped_T_4],
E_k=0.39,
p_0=1.13,
E_p=1.65,
volume=tungsten,
F.Reaction(
reactant=[mobile_T, empty_traps_5],
product=[trapped_T_5],
E_k=0.39,
p_0=1.13,
E_p=1.85,
volume=tungsten,
), F.Reaction(
reactant=[mobile_T, empty_traps_6],
product=[trapped_T_6],
E_k=0.39,
p_0=1.13,
E_p=2.05,
volume=tungsten,
), F.Reaction(
reactant=[mobile_T, empty_traps_7],
product=[trapped_T_7],
k_0=4.57e-7/(1.1e-10**2*6*euro_atom_density),
E_k=0.45,
p_0=1.13,
E_p=1.15,
volume=euro_fer,
), F.Reaction(
reactant=[mobile_T, empty_traps_8],
product=[trapped_T_8],
E_k=0.45,
p_0=1.13,
E_p=1.35,
volume=euro_fer,
), F.Reaction(
reactant=[mobile_T, empty_traps_9],
product=[trapped_T_9],
E_k=0.45,
p_0=1.13,
E_p=1.65,
volume=euro_fer,
), F.Reaction(
reactant=[mobile_T, empty_traps_10],
product=[trapped_T_10],
E_k=0.45,
p_0=1.13,
E_p=1.85,
volume=euro_fer,
), F.Reaction(
reactant=[mobile_T, empty_traps_11],
product=[trapped_T_11],
E_k=0.45,
p_0=1.13,
E_p=2.05,
volume=euro_fer,
my_model._element_for_traps = "DG"
import ufl
phi = 7.15e12
R_p = 9.52e-10
implatantion_flux=F.FixedConcentrationBC(
subdomain=inlet_surf,
#value=lambda T_expr: phi * R_p / (tungsten_mat.D_0 * ufl.exp(-tungsten_mat.E_D / F.k_B / T_expr)),
value=1e14,
species=mobile_T,
Neum_con=F.ParticleFluxBC(subdomain=neumann_surf, value=2.4e+19*2, species=mobile_T)
Diriclet_con=F.FixedConcentrationBC(subdomain=dirichelt_surf, value=4.6e-5*(6.022e23), species=mobile_T)
my_model.boundary_conditions=[implatantion_flux, Diriclet_con, Neum_con]
my_model.sources=[F.ParticleSource(volume=FLiBe, value=1.1e19, species=mobile_T)]
atol=1e-2,
rtol=1e-2,
transient=True,
final_time=1e8,
my_model.settings.stepsize = F.Stepsize(
initial_value=1e7, # passo iniziale piccolo = stabile
growth_factor=1.4, # aumenta lentamente
cutback_factor=0.5, # riduce solo quando serve
target_nb_iterations=20, # default stabile
if flag==1:
F.XDMFExport(
field=mobile_T,
filename= results_folder +"quad_traps/hydrogen_concentration_festim2_q.xdmf"
F.VTXSpeciesExport(filename="quad_traps/Trap_1.bp", field=trapped_T_1),
#F.VTXSpeciesExport(filename="quad_traps/Trap_2.bp", field=trapped_T_2),
#F.VTXSpeciesExport(filename="quad_traps/Trap_3.bp", field=trapped_T_3),
#F.VTXSpeciesExport(filename="quad_traps/Trap_4.bp", field=trapped_T_4),
#F.VTXSpeciesExport(filename="quad_traps/Trap_5.bp", field=trapped_T_5),
#F.VTXSpeciesExport(filename="quad_traps/Trap_6.bp", field=trapped_T_6),
#F.VTXSpeciesExport(filename="quad_traps/Trap_7.bp", field=trapped_T_7),
#F.VTXSpeciesExport(filename="quad_traps/Trap_8.bp", field=trapped_T_8),
#F.VTXSpeciesExport(filename="quad_traps/Trap_9.bp", field=trapped_T_9),
#F.VTXSpeciesExport(filename="quad_traps/Trap_10.bp", field=trapped_T_10),
#F.VTXSpeciesExport(filename="quad_traps/Trap_11.bp", field=trapped_T_11),
# F.XDMFExport(
# field=trapped_T,
# filename= results_folder +"quad_traps/hydrogen_trapped_T_festim2_t.xdmf"
#F.XDMFExport(
# field=empty_traps_1,
# filename= results_folder +"quad_traps/hydrogen_1_festim2_t.xdmf"
#profile = ProfileExport(field=mobile_T, volume=[tungsten, euro_fer, FLiBe],)
F.VTXSpeciesExport(filename= results_folder +"tria_traps/solute.bp", field=trapped_T_1)
F.XDMFExport(
field=mobile_T,
filename=results_folder +"tria/hydrogen_concentration.xdmf",
#F.XDMFExport(
# field=trapped_T,
# filename= results_folder +"tria_traps/hydrogen_trapped_T_festim2_t.xdmf"
#F.XDMFExport(
# filename= results_folder +"tria_traps/hydrogen_1_festim2_t.xdmf"
import dolfinx
from dolfinx import fem, mesh
from ufl import Measure, FacetNormal, jump, grad, Constant, dot
from petsc4py import PETSc
domain = my_model.mesh.mesh
facet_markers = my_model.mesh.define_surface_meshtags()
dS = Measure("dS", domain=domain, subdomain_data=facet_markers)
n = FacetNormal(domain)
c = mobile_T.solution
D_euro = euro_fer_mat.D_0
D_flibe = FLiBe_mat.D_0
D = fem.Constant(domain, PETSc.ScalarType(0.5 * (euro_fer_mat.D_0 + FLiBe_mat.D_0)))
flux_form = jump(-D * grad(c), n) * dS(11)
flux_total = fem.assemble_scalar(fem.form(flux_form))
flux_total = domain.comm.allreduce(flux_total, op=MPI.SUM)
area_form = 1.0 * dS(11)
area_dS11 = fem.assemble_scalar(fem.form(area_form))
area_dS11 = domain.comm.allreduce(area_dS11, op=MPI.SUM) # Flusso medio
flux_mean = flux_total / area_dS11
if domain.comm.rank == 0:
print(f"Flusso totale su dS(11): {flux_total:.4e} [atomi/s]")
print(f"Area della superficie dS(11): {area_dS11:.4e} [m²]")
print(f"Flusso medio su dS(11): {flux_mean:.4e} [atomi/(m²·s)]")
- Would
F.HydrogenTransportProblemDiscontinuous()be more appropriate for a multi-material 2D problem with several trapping sites?
Thanks in advance for any help or suggestions!
Andrea
