Dear Remi,
my apologies for being too brief in my question. I have installed the code using conda and here is the code:
my_model = F.HydrogenTransportProblem()
vertices = np.concatenate(
np.linspace(0, 30e-9, num=200),
np.linspace(30e-9, 3e-6, num=300),
np.linspace(3e-6, 20e-6, num=200),
my_model.mesh = F.Mesh1D(vertices)
D_0=4.1e-07, # m2/s
E_D=0.39, # eV
volume_subdomain = F.VolumeSubdomain1D(id=1, borders=[0, 20e-6], material=tungsten)
left_boundary = F.SurfaceSubdomain1D(id=1, x=0)
right_boundary = F.SurfaceSubdomain1D(id=2, x=20e-6)
my_model.subdomains = [
volume_subdomain,
left_boundary,
right_boundary,
avogadro = 6.02214076e23 # 1/mol
w_atom_density = 6.3e28 / avogadro # atom/m3
H = F.Species(“H”)
trapped_H1 = F.Species(“trapped_H1”, mobile=False)
trapped_H2 = F.Species(“trapped_H2”, mobile=False)
empty_trap1 = F.ImplicitSpecies(n=1.3e-3 * w_atom_density, others=[trapped_H1])
empty_trap2 = F.ImplicitSpecies(n=4e-4 * w_atom_density, others=[trapped_H2])
my_model.species = [H, trapped_H1, trapped_H2]
trapping_reaction_1 = F.Reaction(
reactant=[H, empty_trap1],
product=[trapped_H1],
k_0=4.1e-7 / (1.1e-10**2 * 6 * w_atom_density),
E_k=0.39,
E_p=0.87,
volume=volume_subdomain,
trapping_reaction_2 = F.Reaction(
reactant=[H, empty_trap2],
product=[trapped_H2],
E_k=0.39,
E_p=1.0,
my_model.reactions = [
trapping_reaction_1,
trapping_reaction_2,
import ufl
implantation_time = 400 # s
incident_flux = 3e19/ avogadro # H/m2/s
def ion_flux(t):
return ufl.conditional(t <= implantation_time, incident_flux, 0)
def gaussian_distribution(x, center, width):
return (
1
/ (width * (2 * ufl.pi) ** 0.5)
* ufl.exp(-0.5 * ((x[0] - center) / width) ** 2)
source_term = F.ParticleSource(
value=lambda x, t: ion_flux(t) * gaussian_distribution(x, 4.5e-9, 2.5e-9),
species=H,
my_model.sources = [source_term]
F.FixedConcentrationBC(subdomain=left_boundary, value=0, species=H),
F.FixedConcentrationBC(subdomain=right_boundary, value=0, species=H),
implantation_temp = 300 # K
temperature_ramp = 8 # K/s
start_tds = implantation_time + 50 # s
def temp_fun(t):
if t <= start_tds:
return implantation_temp
return implantation_temp + temperature_ramp * (t - start_tds)
my_model.temperature = temp_fun
my_model.settings = F.Settings(atol=1e-10, rtol=1e-10, final_time=500)
my_model.settings.stepsize = F.Stepsize(
initial_value=0.5,
growth_factor=1.1,
cutback_factor=0.9,
target_nb_iterations=4,
max_stepsize=lambda t: 0.5 if t > start_tds else None,
milestones=[implantation_time, start_tds, start_tds + 50],
left_flux = F.SurfaceFlux(surface=left_boundary, field=H)
right_flux = F.SurfaceFlux(surface=right_boundary, field=H)
total_mobile_H = F.TotalVolume(field=H, volume=volume_subdomain)
total_trapped_H1 = F.TotalVolume(field=trapped_H1, volume=volume_subdomain)
total_trapped_H2 = F.TotalVolume(field=trapped_H2, volume=volume_subdomain)
profile_exports = [
F.Profile1DExport(
field=spe,
times=[implantation_time, start_tds, start_tds + 50],
for spe in [H, trapped_H1, trapped_H2]
total_mobile_H,
total_trapped_H1,
total_trapped_H2,
left_flux,
right_flux,
] + profile_exports
time_labels = [“After implantation”, “Start of TDS”, “50 s after TDS start”]
fig, axs = plt.subplots(3, 3, sharex=True, sharey=“row”, figsize=(12, 8))
for i, profile in enumerate(profile_exports):
axs[i, 0].set_ylabel(profile.field.name)
for j, time in enumerate(profile.t):
axs[0, j].set_title(time_labels[j])
plt.sca(axs[i, j])
plt.plot(profile.x, profile.data[j])
plt.fill_between(
profile.x,
profile.data[j],
alpha=0.2,
for ax in axs.flat:
ax.spines[“top”].set_visible(False)
ax.spines[“right”].set_visible(False)
ax.set_ylim(bottom=0)
plt.xlim(0, 3.5e-6)
axs[2, 0].set_xlabel(“Position (m)”)
t = left_flux.t
flux_total = np.array(left_flux.data) + np.array(right_flux.data)
plt.plot(t, flux_total, linewidth=3)
plt.ylabel(r"Desorption flux (mol m$^{-2} s^{-1}$)")
plt.xlabel(r"Time (s)")
contribution_trap_1 = -np.diff(total_trapped_H1.data) / np.diff(t)
contribution_trap_2 = -np.diff(total_trapped_H2.data) / np.diff(t)
plt.plot(t[1:], contribution_trap_1, linestyle=“–”, color=“grey”)
plt.fill_between(t[1:], 0, contribution_trap_1, facecolor=“grey”, alpha=0.1)
plt.plot(t[1:], contribution_trap_2, linestyle=“–”, color=“grey”)
plt.fill_between(t[1:], 0, contribution_trap_2, facecolor=“grey”, alpha=0.1)
plt.xlim(450, 500)
plt.ylim(-0.2e-5, 1e-5)
The output including the failure is the following:
ld: warning: duplicate -rpath ‘/Users/michael/miniconda3/envs/festim-env/lib’ ignored
Solving HydrogenTransportProblem: 90%|██████████████████████████ | 450/500 [00:04<00:00, 188it/s]Traceback (most recent call last):
File “/Users/michael/plasma/COMPASS-U/hot_wall/festim_scripts/festim_tds_tutorial.py”, line 144, in
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/festim/problem.py”, line 207, in run
self.iterate()
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/festim/problem.py”, line 237, in iterate
_ = self.solver.solve()
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/dolfinx/fem/petsc.py”, line 1347, in solve
self.solver.solve(None, self.x)
File “petsc4py/PETSc/SNES.pyx”, line 1740, in petsc4py.PETSc.SNES.solve
petsc4py.PETSc.Error: error code 91
[0] SNESSolve() at /Users/runner/miniforge3/conda-bld/bld/rattler-build_petsc_1785523000/work/src/snes/interface/snes.c:4968
[0] SNESSolve has not converged
Exception ignored while calling deallocator <function tqdm.del at 0x166a8d170>:
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/tqdm/std.py”, line 1154, in del
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/tqdm/std.py”, line 1310, in close
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/tqdm/std.py”, line 1503, in display
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/tqdm/std.py”, line 1157, in str
File “/Users/michael/miniconda3/envs/festim-env/lib/python3.14/site-packages/tqdm/std.py”, line 576, in format_meter
ImportError: sys.meta_path is None, Python is likely shutting down
