Hello,
I am having a bit of trouble with a model converging. I’m trying to model hydrogen permeation through a nickel membrane through molten FLiBe in a cylindrical geometry, and when I try and calculate the transient solution to the flux of the top surface of the FLiBe the solver is not converging.
Here is an example picture of the model:
There is a nickel membrane, a layer of FLiBe salt, and a nickel wall surrounding both the membrane and the salt.
Here is an example of the log when running the model:
Solving nonlinear variational problem.
Newton iteration 0: r (abs) = 3.143e+25 (tol = 1.000e+20) r (rel) = 1.000e+00 (tol = 1.000e-10)
Newton iteration 1: r (abs) = 4.078e+24 (tol = 1.000e+20) r (rel) = 1.298e-01 (tol = 1.000e-10)
Newton iteration 2: r (abs) = 6.666e+23 (tol = 1.000e+20) r (rel) = 2.121e-02 (tol = 1.000e-10)
Newton iteration 3: r (abs) = 1.949e+23 (tol = 1.000e+20) r (rel) = 6.200e-03 (tol = 1.000e-10)
Newton iteration 4: r (abs) = 1.178e+23 (tol = 1.000e+20) r (rel) = 3.747e-03 (tol = 1.000e-10)
Newton iteration 5: r (abs) = 7.058e+28 (tol = 1.000e+20) r (rel) = 2.246e+03 (tol = 1.000e-10)
Newton iteration 6: r (abs) = 1.765e+28 (tol = 1.000e+20) r (rel) = 5.614e+02 (tol = 1.000e-10)
Newton iteration 7: r (abs) = 4.411e+27 (tol = 1.000e+20) r (rel) = 1.404e+02 (tol = 1.000e-10)
Newton iteration 8: r (abs) = 1.113e+27 (tol = 1.000e+20) r (rel) = 3.540e+01 (tol = 1.000e-10)
Newton iteration 9: r (abs) = 2.782e+26 (tol = 1.000e+20) r (rel) = 8.852e+00 (tol = 1.000e-10)
Newton iteration 10: r (abs) = 3.863e+26 (tol = 1.000e+20) r (rel) = 1.229e+01 (tol = 1.000e-10)
Newton iteration 11: r (abs) = 9.663e+25 (tol = 1.000e+20) r (rel) = 3.075e+00 (tol = 1.000e-10)
Newton iteration 12: r (abs) = 2.638e+25 (tol = 1.000e+20) r (rel) = 8.393e-01 (tol = 1.000e-10)
Newton iteration 13: r (abs) = 1.408e+25 (tol = 1.000e+20) r (rel) = 4.480e-01 (tol = 1.000e-10)
Here are the meshing files generated of the geometry
8mm_thick_mesh.zip (910.8 KB)
And these meshing files gives the ids of
{-6: ['salt_volume'], -7: ['salt_top'], -8: ['membrane_bottom'], -9: ['side_wall'], -10: ['nickel_volume']}
And here is the code that I am using to try and solve the transient problem:
import h_transport_materials as htm
P_up = 100
def make_model(folder):
model.mesh = F.MeshFromXDMF(
volume_file=f"{folder}/mesh_domains.xdmf", boundary_file=f"{folder}/mesh_boundaries.xdmf"
# Material properties
flibe_diffusivity = htm.diffusivities.filter(material=htm.FLIBE, author = 'calderoni')[0]
flibe_solubility = htm.solubilities.filter(material=htm.FLIBE, author = 'calderoni')[0]
flibe = F.Material(
id=6, # Given by the meshing file
D_0=flibe_diffusivity.pre_exp.magnitude,
E_D=flibe_diffusivity.act_energy.magnitude,
S_0 = flibe_solubility.pre_exp.magnitude,
E_S = flibe_solubility.act_energy.magnitude,
solubility_law = "henry"
nickel_diffusivity = htm.diffusivities.filter(material=htm.NICKEL).mean()
nickel_solubility = htm.solubilities.filter(material=htm.NICKEL).mean()
nickel = F.Material(
id = 10,
D_0 = nickel_diffusivity.pre_exp.magnitude,
E_D = nickel_diffusivity.act_energy.magnitude,
S_0 = nickel_solubility.pre_exp.magnitude,
E_S = nickel_solubility.act_energy.magnitude
model.materials = [nickel, flibe]
F.SievertsBC(surfaces=[8], S_0=nickel.S_0, E_S=nickel.E_S, pressure = P_up),
# Dirichlet BCs on salt top and outside of side wall
F.DirichletBC(field="solute", value=0, surfaces=[7]),
F.DirichletBC(field="solute", value = 0, surfaces = [9])
model.T = F.Temperature(973)
model.exports = [F.XDMFExport("solute", folder = folder)]
absolute_tolerance=1e20,
chemical_pot=True,
final_time = 8*3600
model.dt = F.Stepsize(initial_value = 10, stepsize_change_ratio = 1.1)
model.log_level = 20
return model
if __name__ == "__main__":
folder = '3D_cad/8mm_thick'
model = make_model(folder)
I suspect that the meshing might have something to do with the lack of convergence or maybe an improper implementation of boundary conditions. Some help and guidance would be much appreciated!
