Having some issues running a multi-material simulation with a salt-metal interface.
I have a model here with half salt, half metal, with a time-dependent fixed concentration at the salt boundary and insulated on the end of the metal.
It seems the hydrogen enters the metal, but then cant leave despite there being no traps.
Here is a gif to illustrate:
![[animate output image]](https://global.discourse-cdn.com/free1/uploads/festim/original/1X/5e4a2ccffe37bc8eb9c680a9b04ada3659b8dabf.gif)
here is the script to reproduce (runs on latest version of fenicsx branch commit - # d308842)
from dolfinx.log import set_log_level, LogLevel
my_model = F.HydrogenTransportProblemDiscontinuous()
vertices = np.concatenate(
np.linspace(0, 0.03, num=300),
np.linspace(0.03, 0.06, num=300),
my_mesh = F.Mesh1D(vertices=vertices)
my_model.mesh = my_mesh
mat_flibe = F.Material(
D_0=9.3e-7,
E_D=0.435,
K_S_0=4.76e22,
E_K_S=0.363,
solubility_law="henry",
mat_inconel = F.Material(
D_0=1.75e-6,
E_D=0.545,
K_S_0=1.26e23,
E_K_S=0.109,
solubility_law="sievert",
vol_flibe = F.VolumeSubdomain1D(id=1, material=mat_flibe, borders=[0, 0.03])
vol_inconel = F.VolumeSubdomain1D(id=2, material=mat_inconel, borders=[0.03, 0.06])
inner_flibe_surface = F.SurfaceSubdomain1D(id=3, x=0)
outer_radius_surface = F.SurfaceSubdomain1D(id=4, x=0.06)
my_model.subdomains = [
vol_inconel,
vol_flibe,
inner_flibe_surface,
outer_radius_surface,
salt_metal_interface = F.Interface(
id=5, subdomains=(vol_flibe, vol_inconel), penalty_term=1e25
my_model.interfaces = [salt_metal_interface]
my_model.surface_to_volume = {
inner_flibe_surface: vol_flibe,
outer_radius_surface: vol_inconel,
T = F.Species("T", mobile=True, subdomains=[vol_flibe, vol_inconel])
my_model.species = [T]
irradiation_time = 12 * 3600
def my_value(t):
if t < irradiation_time:
return 5e4
return 0
F.FixedConcentrationBC(
subdomain=inner_flibe_surface, species=T, value=lambda t: my_value(t)
my_model.temperature = 923 # 650 degC
dt = F.Stepsize(
100,
growth_factor=1.1,
cutback_factor=0.9,
target_nb_iterations=4,
milestones=[irradiation_time],
transient=True,
atol=1e-10,
rtol=1e-12,
final_time=30 * 24 * 3600,
stepsize=dt,
F.VTXSpeciesExport(
"results/tritium_concentration_flibe_1D.bp", field=T, subdomain=vol_flibe
F.VTXSpeciesExport(
"results/tritium_concentration_inconel_1D.bp", field=T, subdomain=vol_inconel
set_log_level(LogLevel.INFO)
