Simulation does not converge when material properties inversely proportional to temperature
Hello all.
I tried setting the temperature-dependent material properties for HeatTransferProblem using the polynomial expressions from this paper.
Unfortunately, the simulation model instantly diverges with these expressions. I suppose the issue appears, since the polynomials include terms ∝T-2.
MWE:
def thermal_cond_function(T):
    return 1 + T**2 + 1 / T
model.mesh = F.MeshFromVertices(vertices=np.linspace(0, 1, num=1000))
    absolute_tolerance=1e-10, relative_tolerance=1e-10, transient=False
mat = F.Material(id=1, D_0=1, E_D=0.2, thermal_cond=thermal_cond_function)
model.materials = mat
model.T = F.HeatTransferProblem(transient=False)
If the last term in thermal_cond_function is removed, the simulation runs without problems.
@VVKulagin the problem is that because of that division, if T=0 then the thermal conductivity is nan. It can be verified by adding model.log_level = 20.
One way to fix this is adding an epsilon to the division so that it’s never zero.
    return 1 + T**2 + 1 / (T + f.DOLFIN_EPS)
model.T = F.HeatTransferProblem(transient=False, initial_condition=1)
model.boundary_conditions = [F.DirichletBC(surfaces=[1, 2], value=1 + F.x, field="T")]
Running the following code produces:
f.plot(model.T.T)
Alternatively you can also do:
    return 1 + T**2 + 1 / (T + 1e-12)
