Hello there,
I am currently running simulations of Hydrogen transport (with multiple isotopes) in a 1D tungsten slab.
I managed to export and read the concentration profiles of mobile species using XDMFExport. However, I am getting an error every time I try to export the concentration profiles of trapped species using the same XDMFExport function.
I attach here what I tried to set up as MWE:
import festim as Fmy_model = F.HydrogenTransportProblem()
Domain length [m]
L = 12e-3
vertices_uniform = np.linspace(0, L, num=5000)
my_model.mesh = F.Mesh1D(vertices_uniform)w_atom_density = 6.3e28 # [atoms/m^3] tungsten atomic density (hard-coded)
tungsten = F.Material(D_0=4.1e-7, E_D=0.39, name=“tungsten”)vol = F.VolumeSubdomain1D(id=1, borders=[0, L], material=tungsten)
surf_left = F.SurfaceSubdomain1D(id=1, x=0)
surf_right = F.SurfaceSubdomain1D(id=2, x=L)
my_model.subdomains = [vol, surf_left, surf_right]Two mobile species (D, T) and one trap with two occupied states
mobile_D = F.Species(“D”)
mobile_T = F.Species(“T”)
trap1_D = F.Species(“trap1_D”, mobile=False)
trap1_T = F.Species(“trap1_T”, mobile=False)Empty trap population (implicit) shared by both isotopes
empty_t1 = F.ImplicitSpecies(
name=“empty_trap1”,
n=1.3e-3 * w_atom_density, # [m^-3] trap density
others=[trap1_D, trap1_T],
)my_model.species = [mobile_D, mobile_T, trap1_D, trap1_T]
R0 = 4.1e-7 / (1.1e-10**2 * 6 * w_atom_density)
reactions = [
D + empty_trap1 → trap1_D
F.Reaction(
k_0=R0, E_k=0.39,
p_0=1e13, E_p=0.87,
reactant=[mobile_D, empty_t1],
product=[trap1_D],
volume=vol,
),T + empty_trap1 → trap1_T
F.Reaction(
k_0=R0, E_k=0.39,
p_0=1e13, E_p=0.87,
reactant=[mobile_T, empty_t1],
product=[trap1_T],
volume=vol,
my_model.reactions = reactionsTemp = 500 #T in K
my_model.temperature = Tempbc_D_value = 2e23
bc_T_value = 6e23bc_D = F.DirichletBC(subdomain=surf_left, value=bc_D_value, species=“D”)
bc_T = F.DirichletBC(subdomain=surf_left, value=bc_T_value, species=“T”)
my_model.boundary_conditions = [bc_D, bc_T]folder = “results”
F.XDMFExport(f"{folder}/trap1_D.xdmf", field=trap1_D),
]my_model.settings = F.Settings(
transient=True,
final_time=1000.0,
atol=1e10,
rtol=1e-10,
max_iterations=50,
stepsize=F.Stepsize(
1e-2,
growth_factor=1.1,
cutback_factor=0.3,
target_nb_iterations=5,
max_stepsize=1,
my_model.run
Giving the following error:
Solving HydrogenTransportProblem: 0%| | 0.00/1.00k [00:00<?, ?it/s]Traceback (most recent call last):
File “/home/ITER/llealsa/FESTIM-2/discourse_xdmf_export/MWE.py”, line 88, in
File “/home/ITER/llealsa/miniconda3/envs/festim2a/lib/python3.10/site-packages/festim/problem.py”, line 166, in run
self.iterate()
File “/home/ITER/llealsa/miniconda3/envs/festim2a/lib/python3.10/site-packages/festim/problem.py”, line 197, in iterate
self.post_processing()
File “/home/ITER/llealsa/miniconda3/envs/festim2a/lib/python3.10/site-packages/festim/hydrogen_transport_problem.py”, line 971, in post_processing
export.write(float(self.t))
File “/home/ITER/llealsa/miniconda3/envs/festim2a/lib/python3.10/site-packages/festim/exports/xdmf.py”, line 79, in write
self._writer.write_function(field.post_processing_solution, t)
File “/home/ITER/llealsa/miniconda3/envs/festim2a/lib/python3.10/site-packages/dolfinx/io/utils.py”, line 252, in write_function
super().write_function(getattr(u, “_cpp_object”, u), t, mesh_xpath)
RuntimeError: Function and Mesh dof layouts do not match. Maybe the Function needs to be interpolated?Solving HydrogenTransportProblem: 0%| | 0.01/1.00k [00:00<5:37:20, 20.2s/it]
I am using FESTIM’s 2.0a4 version in a conda environment (installed via conda-forge).
I could run the simulations using VTXSpeciesExport for both mobile and trapped species, however I am having a hard time trying to correctly visualize and work with the output data.
Is it possible to export the concentration profiles of trapped species using the XDMFExport function? If so, I would really appreciate the help to solve my current issue.
Thank you very much for your help and best regards.
