Thanks for the quick answer. I have now fixed the paths and they are correct. However, I am still facing an issue when importing the mesh. This is the error I get:
File "/home/ndrea_i_aio/festim/TESI/MODEL_W_EURO_FLiBe", line 6, in <module>
my_model.mesh = F.MeshFromXDMF(volume_file="/home/ndrea_i_aio/festim/TESI/mesh_domains.xdmf", boundary_file="/home/ndrea_i_aio/festim/TESI/mesh_boundaries.xdmf")
File "/home/ndrea_i_aio/miniconda3/envs/festim_env_2/lib/python3.13/site-packages/festim/meshing/mesh_from_xdmf.py", line 28, in __init__
self.define_markers()
File "/home/ndrea_i_aio/miniconda3/envs/festim_env_2/lib/python3.13/site-packages/festim/meshing/mesh_from_xdmf.py", line 43, in define_markers
f.XDMFFile(self.boundary_file).read(surface_markers, "f")
RuntimeError:
*** DOLFIN encountered an error. If you are not able to resolve this issue
*** using the information listed below, you can ask for help at
*** fenics-support@googlegroups.com
*** Remember to include the error message listed below and, if possible,
*** include a *minimal* running example to reproduce the error.
*** Error: Unable to recognise cell type.
*** Reason: Unknown value "".
*** Where: This error was encountered inside XDMFFile.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: ec7503cef5f328d4927ba1050abe55c3519ac4e9
ERROR conda.cli.main_run:execute(127): `conda run python /home/ndrea_i_aio/festim/TESI/MODEL_W_EURO_FLiBe` failed. (See above for error)
Could this error be due to an incompatibility between FESTIM (Fenics 2019) and DolfinX?
I am also including the code I use to generate the mesh:
import gmsh
from dolfinx.io import gmshio
import pyvista
from dolfinx import plot
# Geometry
wi_tun = 1e-2 # tungsten thickness
wi_euro = 3e-2 # EUROFER thickness
wi_FLiBe = 2e-2 # FLiBe thickness
Le = 1
def create_three_region_mesh():
width_tung = wi_tun
width_euro = wi_euro
width_FLiBe = wi_FLiBe
length = Le
gmsh.initialize()
gmsh.model.add("three_regions")
# Points
p1 = gmsh.model.geo.addPoint(0, 0, 0)
p2 = gmsh.model.geo.addPoint(width_tung, 0, 0)
p3 = gmsh.model.geo.addPoint(0, length, 0)
p4 = gmsh.model.geo.addPoint(width_tung, length, 0)
p5 = gmsh.model.geo.addPoint(width_tung + width_euro, 0, 0)
p6 = gmsh.model.geo.addPoint(width_tung + width_euro, length, 0)
p7 = gmsh.model.geo.addPoint(width_tung + width_euro + width_FLiBe, 0, 0)
p8 = gmsh.model.geo.addPoint(width_tung + width_euro + width_FLiBe, length, 0)
# Lines Tungsten
l1 = gmsh.model.geo.addLine(p1, p2)
l2 = gmsh.model.geo.addLine(p3, p1)
l3 = gmsh.model.geo.addLine(p4, p3)
l4 = gmsh.model.geo.addLine(p2, p4)
# Lines EUROFER
l5 = gmsh.model.geo.addLine(p2, p5)
l6 = gmsh.model.geo.addLine(p5, p6)
l7 = gmsh.model.geo.addLine(p6, p4)
# Lines FLiBe
l8 = gmsh.model.geo.addLine(p5, p7)
l9 = gmsh.model.geo.addLine(p7, p8)
l10 = gmsh.model.geo.addLine(p8, p6)
l11 = gmsh.model.geo.addLine(p6, p5)
# Curve Loops
tung_loop = gmsh.model.geo.addCurveLoop([l1, l4, l3, l2])
euro_loop = gmsh.model.geo.addCurveLoop([l5, l6, l7, -l4])
flibe_loop = gmsh.model.geo.addCurveLoop([l8, l9, l10, l11])
# Surfaces
tung_surf = gmsh.model.geo.addPlaneSurface([tung_loop])
euro_surf = gmsh.model.geo.addPlaneSurface([euro_loop])
flibe_surf = gmsh.model.geo.addPlaneSurface([flibe_loop])
gmsh.model.geo.synchronize()
# Mesh size
gmsh.option.setNumber("Mesh.MeshSizeMin", 0.02)
gmsh.option.setNumber("Mesh.MeshSizeMax", 0.02)
# Physical groups
gmsh.model.addPhysicalGroup(2, [tung_surf], 1)
gmsh.model.setPhysicalName(2, 1, "Tungsten")
gmsh.model.addPhysicalGroup(2, [euro_surf], 2)
gmsh.model.setPhysicalName(2, 2, "EuroFer")
gmsh.model.addPhysicalGroup(2, [flibe_surf], 3)
gmsh.model.setPhysicalName(2, 3, "FLiBe")
gmsh.model.addPhysicalGroup(1, [l2], 4) # Left
gmsh.model.addPhysicalGroup(1, [l9], 5) # Right
gmsh.model.addPhysicalGroup(1, [l3, l7, l10], 6) # Top
gmsh.model.addPhysicalGroup(1, [l1, l5, l8], 7) # Bottom
gmsh.model.addPhysicalGroup(1, [l4], 8) # Interface W-Euro
gmsh.model.addPhysicalGroup(1, [l11], 9) # Interface Euro-FLiBe
gmsh.model.mesh.generate(2)
# Conversion to dolfinx
mesh_2d, cell_tags, facet_tags = gmshio.model_to_mesh(
gmsh.model, MPI.COMM_WORLD, 0, gdim=2
gmsh.finalize()
total_width = width_tung + width_euro + width_FLiBe
return mesh_2d, total_width, width_tung, width_euro, width_FLiBe, cell_tags, facet_tags
mesh_2d, total_width, width_tung, width_euro, width_FLiBe, cell_tags, facet_tags = create_three_region_mesh()
# Export
from dolfinx.io import XDMFFile
output_dir = "TESI"
os.makedirs(output_dir, exist_ok=True)
domains_file = os.path.join(output_dir, "mesh_domains.xdmf")
with XDMFFile(MPI.COMM_WORLD, domains_file, "w") as xdmf:
xdmf.write_mesh(mesh_2d)
xdmf.write_meshtags(cell_tags, mesh_2d.geometry, geometry_xpath="/Mesh/Geometry")
boundaries_file = os.path.join(output_dir, "mesh_boundaries.xdmf")
with XDMFFile(MPI.COMM_WORLD, boundaries_file, "w") as xdmf:
xdmf.write_meshtags(facet_tags, mesh_2d.geometry, geometry_xpath="/Mesh/Geometry")
Thanks in advance!
