Two Layered Monoblock
Hi,
I’m trying to run a simulation for a two-layer monoblock in 2D, but I think there are issues when applying the mesh that I have created to FESTIM when it comes to applying surface boundary conditions. When plotting the temperature field after running the simulation it does not vary as per the given boundary conditions, which are 800K on the left, top, bottom and inner curved surface, and 400K at the interface between the tungsten and CuCrZr and I think the error is with how I am defining and marking the curved surfaces.
Here is how I am generating the mesh
from fenics import RectangleMesh, MeshFunction, Point, CompiledSubDomain, plot
from scipy.constants import Avogadro
from dolfin import *
from mshr import *
left_id = 1
top_id = 2
bottom_id = 3
outer_surface_id = 4
inner_surface_id = 5
outer_layer_id = 1
inner_layer_id = 2
def create_mesh(width, height, inner_radius, outer_radius, n):
    y_min = -height/2
    y_max = height/2
    x_max = width/2
    tol = 1e-14
    class InnerSemiCircleBoundary(SubDomain):
        def inside(self, x, on_boundary):
            return on_boundary and  near((x[0]-x_max)*(x[0]-x_max)+(x[1]*x[1]), inner_radius*inner_radius, tol)
    class OuterSemiCircleBoundary(SubDomain):
            return on_boundary and near((x[0]-x_max)*(x[0]-x_max)+(x[1]*x[1]), outer_radius*outer_radius, tol)
    base = Rectangle(Point(0, y_min), Point(x_max, y_max))
    inner_circle = Circle(Point(x_max, 0), inner_radius)
    domain = base - inner_circle
    full_mesh = generate_mesh(domain, n)
    surface_markers = MeshFunction("size_t", full_mesh, full_mesh.topology().dim()-1)
    surface_markers.set_all(0)
    inner_circle_boundary = InnerSemiCircleBoundary()
    outer_circle_boundary = OuterSemiCircleBoundary()
    left_surface = CompiledSubDomain('near(x[0], 0, tol)', tol = tol)
    top_surface = CompiledSubDomain('near(x[1], y_max, tol)', y_max=y_max, tol = tol)
    bottom_surface = CompiledSubDomain('near(x[1], y_min, tol)', y_min = y_min, tol = tol)
    left_surface.mark(surface_markers, left_id)
    top_surface.mark(surface_markers, top_id)
    bottom_surface.mark(surface_markers, bottom_id)
    inner_circle_boundary.mark(surface_markers, inner_surface_id)
    outer_circle_boundary.mark(surface_markers, outer_surface_id)
    volume_markers = MeshFunction("size_t", full_mesh, full_mesh.topology().dim())
    volume_markers.set_all(1)
    outer_layer_volume = CompiledSubDomain('(x[0]-x_max)*(x[0]-x_max)+x[1]*x[1]>outer_radius*outer_radius+tol',
                                           outer_radius = outer_radius,x_max = x_max, y_min = y_min, y_max = y_max, tol = tol)
    inner_layer_volume = CompiledSubDomain('(x[0]-x_max)*(x[0]-x_max)+x[1]*x[1] < outer_radius*outer_radius-tol',
                                        x_max = x_max, outer_radius=outer_radius, inner_radius = inner_radius, tol=tol)
    outer_layer_volume.mark(volume_markers, outer_layer_id)
    inner_layer_volume.mark(volume_markers, inner_layer_id)
    return full_mesh, surface_markers, volume_markers
and then I am trying to run this through the following FESTIM simulation
def simulation(width, height, outer_radius, inner_radius, flux, mean_depth, temperatures, abs_tolerance, rel_tolerance, n, simulation_time, folder):
   tungsten = F.Material(id = 1,
                         D_0 = 1.5e-7,
                         E_D = 0.265,
                         S_0 = 2.7e24,
                         E_S = 1.14,
                         thermal_cond = 173)
   cucrzr = F.Material(id=2,
                       D_0=4.8e-7,
                       E_D = 0.42,
                       S_0=4.27e23,
                       E_S=0.39,
                       thermal_cond = 320)
   mesh, surface_markers, volume_markers = create_mesh(width, height, inner_radius, outer_radius, n)
   model.mesh=F.Mesh(mesh=mesh, surface_markers=surface_markers, volume_markers=volume_markers)
   model.materials = [tungsten, cucrzr]
   model.T = F.HeatTransferProblem(transient = False)
   bcs = [F.ImplantationDirichlet(surfaces=left_id,
                                                  phi=flux,
                                                  R_p=mean_depth,
                                                  D_0=1.5e-07,
                                                  E_D=0.265),
                               F.DirichletBC(
                                   surfaces = [bottom_id, top_id, inner_surface_id],
                                   value = 0,
                                   field = 0),
                               F.DirichletBC(
                                   surfaces = [left_id, top_id, bottom_id],
                                   value = temperatures[0],
                                   field = 'T'),
                               F.DirichletBC(
                                   surfaces=[outer_surface_id],
                                   value = temperatures[1],
                                   field = 'T'
                               F.DirichletBC(
                                   surfaces = inner_surface_id,
                                   value = temperatures[2],
                                   field = 'T'
   model.boundary_conditions=bcs
       absolute_tolerance=abs_tolerance,
       relative_tolerance=rel_tolerance,
       chemical_pot=True,
       transient = False,
       traps_element_type = "DG"
   total_mobile_1 = F.TotalVolume("solute", volume=1)
   total_mobile_2 = F.TotalVolume("solute", volume = 2)
   retention_1 = F.TotalVolume("retention", volume =1)
   retention_2 = F.TotalVolume("retention", volume = 2)
   derived = [total_mobile_1, total_mobile_2, retention_1, retention_2]
   model.exports = F.Exports([F.XDMFExport("T", filename = folder + "/temp.xdmf"),
       F.XDMFExport("solute", filename=folder+"/solute.xdmf"),
       F.XDMFExport("retention", filename=folder+"/retention.xdmf"),
       F.DerivedQuantities(derived, filename = folder + "/derived_qs.csv"),
   return model
model = simulation(15e-3, 10e-3, 4e-3, 2e-3, 1e22, 1e-8, [800,400,800], 1e12, 1e-12, 200, 1e7, "simulation")
Here is the plotting code:
from fenics import XDMFFile, FunctionSpace, Function, plot
def load_xdmf(mesh, filename, field, element="DG", counter=-1):
    """Loads a XDMF file and store its content to a fenics.Function
        mesh (fenics.mesh): the mesh of the function
        filename (str): the XDMF filename
        field (str): the name of the field in the XDMF file
        element (str, optional): Finite element of the function.
            Defaults to "CG".
        counter (int, optional): timestep in the file, -1 is the
            last timestep. Defaults to -1.
    Returns:
        fenics.Function: the content of the XDMF file as a Function
    V = FunctionSpace(mesh, element, 1)
    u = Function(V)
    XDMFFile(filename).read_checkpoint(u, field, counter)
    return u
mesh = model.mesh.mesh
mobile_concentration = load_xdmf(mesh, "simulation/solute.xdmf", "mobile_concentration", element = "DG")
retention = load_xdmf(mesh, "simulation/retention.xdmf", "retention")
temperature = load_xdmf(mesh, "simulation/temp.xdmf", "temperature")
CF = plot(retention)
CB = plt.colorbar(CF)
CF = plot(mobile_concentration)
CF = plot(temperature)
Any help would be appreciated
Hi @celyn and welcome, can you fix the formatting of your post please? some code is not in the code blocks.
Also, how do you plot this figure? could you provide the code for this too?
In general, when describing an issue, you need to make sure your problem can be reproduced with a script that can be run easily
Hi, I’ve edited the post to include the plotting code and made sure it’s all in the code blocks
Could you also add the imports needed (i guess fenics, and maybe others) for the mesh creation block?
Hi sorry!
I think I should have added all the imports now
The second code block is still not runnable it misses the function definition
Anyway, I believe I have reproduced your issue with the following Minimal Working Example (I’ve simplified it to make it more digest):
from fenics import (
    RectangleMesh,
    MeshFunction,
    Point,
    CompiledSubDomain,
    plot,
    near,
    SubDomain,
    DOLFIN_EPS,
    XDMFFile,
from mshr import *
left_id = 1
right_id = 2
top_id = 3
bottom_id = 4
outer_surface_id = 5
inner_surface_id = 6
outer_layer_id = 1
inner_layer_id = 2
def create_mesh_semi(width, height, inner_radius, outer_radius, n):
    y_min = -height / 2
    y_max = height / 2
    x_min = -width / 2
    x_max = width / 2
    tol = 1e-14
            return (
                on_boundary
                and near(
                    (x[0] - x_max) * (x[0] - x_max) + (x[1] * x[1]),
                    inner_radius * inner_radius,
                    tol,
                and x[0] < x_max - DOLFIN_EPS
            return (
                on_boundary
                and near(
                    outer_radius * outer_radius,
                    tol,
    inner_circle = Circle(Point(x_max, 0), inner_radius, segments=n)
    outer_circle = Circle(Point(x_max, 0), outer_radius, segments=n)
    surface_markers = MeshFunction("size_t", full_mesh, full_mesh.topology().dim() - 1)
    left_surface = CompiledSubDomain("near(x[0], 0, tol)", tol=tol)
    right_surface = CompiledSubDomain("near(x[0], x_max, tol)", x_max=x_max, tol=tol)
    top_surface = CompiledSubDomain("near(x[1], y_max, tol)", y_max=y_max, tol=tol)
    bottom_surface = CompiledSubDomain("near(x[1], y_min, tol)", y_min=y_min, tol=tol)
    right_surface.mark(surface_markers, right_id)
    XDMFFile("semi_circle_trans/sm.xdmf").write(surface_markers)
    XDMFFile("semi_circle_trans/vm.xdmf").write(volume_markers)
def semi_sim(
    width,
    height,
    outer_radius,
    inner_radius,
    flux,
    mean_depth,
    temperatures,
    abs_tolerance,
    rel_tolerance,
    n,
    simulation_time,
    gradual,
    percent,
    folder,
    mesh, surface_markers, volume_markers = create_mesh_semi(
    model.mesh = F.Mesh(
    print("Mesh created")
    model.materials = F.Material(id=1, D_0=1, E_D=0, thermal_cond=1)
    model.T = F.HeatTransferProblem(transient=False)
        F.DirichletBC(
            surfaces=[left_id, right_id, top_id, bottom_id],
            value=temperatures[0],
            field="T",
        F.DirichletBC(surfaces=outer_surface_id, value=temperatures[1], field="T"),
        F.DirichletBC(surfaces=inner_surface_id, value=temperatures[2], field="T"),
    print("Settings set")
    model.exports = F.Exports([F.XDMFExport("T", filename=folder + "/temp.xdmf")])
    print("Exports set")
    return model
model = semi_sim(
    10e-3,
    10e-3,
    4e-3,
    2e-3,
    1e22,
    1e-8,
    [873, 773, 573],
    1e10,
    1e-10,
    20,
    1e7,
    False,
    0.01,
    "semi_circle_trans",
This produces the following temperature field when visualised in paraview:
The issue is that the surfaces outer_surface_id and inner_surface_id are not tagged. You can see this by inspecting your surface markers and volume markers in Paraview, first export them to XDMF with
This is the surface markers file. You see that the maximum value is 4, there are no facets tagged with 5 and 6.
You can also change the log level of the simulation to 30 to display warnings and more info:
model.log_level = 30
And the simulation logs now prints:
Mesh created
Settings set
Exports set
Defining variational problem heat transfers
Solving stationary heat equation
  *** Warning: Found no facets matching domain for boundary condition.
Defining initial values
Defining source terms
Defining boundary conditions
Solving steady state problem...
Solved problem in 0.00 s
This is therefore a meshing issue. For complex meshes I recommend using dedicated meshing tools like SALOME or GMSH (we have a meshing example for SALOME).
There could be ways to get around this with mshr but it may be tricky (I’ll see if I can come up with something)
@celyn this meshing function seems to achieve the expected goal
    y_min = -height / 2
    y_max = height / 2
    x_min = -width / 2
    x_max = width / 2
    centre = (x_max, 0)
    tol = 1e-14
            r = ((x[0] - centre[0]) ** 2 + (x[1] - centre[1]) ** 2) ** 0.5
            return (
                near(r, inner_radius, 1e-3)
                and on_boundary
                and centre[1] - inner_radius <= x[1] <= centre[1] + inner_radius
            return near(r, outer_radius, 1e-4)
    right_rectangle = Rectangle(Point(x_max, y_min), Point(2 * x_max, y_max))
    inner_circle = Circle(Point(*centre), inner_radius, segments=n)
    outer_circle = Circle(Point(*centre), outer_radius, segments=n)
    cucrzr = outer_circle - inner_circle
    tungsten = base - outer_circle
    domain = tungsten + cucrzr
    domain = domain - right_rectangle
    # create domains to have different materials well defined
    domain.set_subdomain(outer_layer_id, tungsten)
    domain.set_subdomain(inner_layer_id, cucrzr)
    # TODO fix this to what it was before
    # export the markers to XDMF
These are the surface markers:
and this is the temperature field:
Note: you should not try to set a temperature boundary condition on the interface subdomain (between the tungsten and cucrzr) it doesn’t make sense.
Moreover, assuming this is a monoblock-like model, you shouldn’t have boundary conditions on the plane of symmetry either. In fact you should have a no flux BC here (which is the default behaviour when you don’t set any BC on this surface).
Thank you! this appears to have fixed my issue
