.xdmf from 2D .msh
Happy New Year everyone!
I just tried to create .xdmf files from a 2D .msh file using Python script from
https://festim.readthedocs.io/en/latest/userguide/mesh.html#converting-meshes-using-meshio
And obtained:
File “/Users/mlavrent/meshio/msh2xdmf-festim.py”, line 27, in
tetra_cells = np.concatenate(tetra_cells_list)
File “<array_function internals>”, line 200, in concatenate
ValueError: need at least one array to concatenate
Does this mean the script only works with 3D .xdmf?
Yes I think this script in the documentation will only work with 3D geometries, you may have to swap all the mentions of “triangle” for “line” and “tetra”’ for “triangle”
Happy new year @miklavrent !
As @jhdark said this script can be applied for a 2D .msh file with a few changes:
Consider this:
import meshio
msh = meshio.read("my_mesh.msh")
# Initialize lists to store cells and their corresponding data
triangle_cells_list = []
line_cells_list = []
triangle_data_list = []
line_data_list = []
# Extract cell data for all types
for cell in msh.cells:
    if cell.type == "triangle":
        triangle_cells_list.append(cell.data)
    elif cell.type == "line":
        line_cells_list.append(cell.data)
# Extract physical tags
for key, data in msh.cell_data_dict["gmsh:physical"].items():
    if key == "triangle":
        triangle_data_list.append(data)
    elif key == "line":
        line_data_list.append(data)
# Concatenate all linehedral cells and their data
line_cells = np.concatenate(line_cells_list)
line_data = np.concatenate(line_data_list)
# Concatenate all triangular cells and their data
triangle_cells = np.concatenate(triangle_cells_list)
triangle_data = np.concatenate(triangle_data_list)
# Create the linehedral mesh
line_mesh = meshio.Mesh(
    points=msh.points,
    cells=[("line", line_cells)],
    cell_data={"f": [line_data]},
# Create the triangular mesh for the surface
triangle_mesh = meshio.Mesh(
    points=msh.points,
    cells=[("triangle", triangle_cells)],
    cell_data={"f": [triangle_data]},
# Write the mesh files
meshio.write("volume_mesh.xdmf", triangle_mesh)
meshio.write("surface_mesh.xdmf", line_mesh)
Let me know if that works
Thank you James and Remi, yes it works now!
