Inhomogeneous Dirichlet BC from csv file
I have a y[m],cm[m-3] csv file and I would like to apply these values as an inhomogeneous Dirichlet boundary condition along one of the 1D boundary of my domain (here is a small sketch, if understandable).
I created a interpolation function with scipy.interpolate.interp1d called cm_f
  input_file_cm = 'concentration.csv'
  data = np.loadtxt(input_file_cm,skiprows=8)
  y = data[:,0]-data[0,0]
  cm = data[:,1]
  cm_f = interp1d(y,cm)
and I thought I could use that directly in the value argument of DirichletBC()
hydrogen_BFS = F.DirichletBC(
     value = bc.cm_f,
     surfaces = id.id_BFS,
     field=0
However, the execution of FESTIM reply during the “Defining boundary conditions phase”
I have been told that sympy.Piecewise could do the job too (but there are around 200 data points, is it ok ?).
thank you very much if someone has an idea
Hi @ehodille
A few tips for the future:
  • if you can post error messages as code blocks (using triple ``` ) this would help with things like googling error messages and such
  • the code blocks that you added are not reproducible (ie I can not just run them and reproduce your issue). For example, I don’t know what the variables bc and id are in bc.cm_f and id.id_BFS, respectively.
    To get an answer quickly, it is recommended to produce what we call a MWE (Minimal Working Example).
In your case, I was able to reproduce what I believe is your issue with this MWE (although 1D):
my_model.mesh = F.MeshFromVertices(vertices=np.linspace(0, 7e-6, num=1001))
my_model.materials = F.Material(id=1, D_0=1e-7, E_D=0.2)
my_model.T = F.Temperature(value=300)
from scipy.interpolate import interp1d
y = [0, 1, 2, 3]
cm = [0, 2, 3, 5]
cm_f = interp1d(y, cm)
    F.DirichletBC(surfaces=[1], value=cm_f, field=0),
    absolute_tolerance=1e-1, relative_tolerance=1e-10, transient=False  # s
and the error message is:
Defining initial values
Defining variational problem
Defining source terms
  File "/home/remidm/mikhail/test.py", line 28, in <module>
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/festim/generic_simulation.py", line 298, in initialise
    self.h_transport_problem.initialise(self.mesh, self.materials, self.dt)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/festim/h_transport_problem.py", line 77, in initialise
    self.create_dirichlet_bcs(materials, mesh)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/festim/h_transport_problem.py", line 219, in create_dirichlet_bcs
    bc.create_dirichletbc(
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/festim/boundary_conditions/dirichlets/dirichlet_bc.py", line 79, in create_dirichletbc
    self.create_expression(T)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/festim/boundary_conditions/dirichlets/dirichlet_bc.py", line 29, in create_expression
    value_BC = sp.printing.ccode(self.value)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/sympy/printing/codeprinter.py", line 752, in ccode
    return c_code_printers[standard.lower()](settings).doprint(expr, assign_to)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/sympy/printing/codeprinter.py", line 162, in doprint
    expr = _handle_assign_to(expr, assign_to)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/sympy/printing/codeprinter.py", line 146, in _handle_assign_to
    return sympify(expr)
  File "/home/remidm/miniconda3/envs/festim-env-mikhail/lib/python3.11/site-packages/sympy/core/sympify.py", line 465, in sympify
    raise SympifyError('cannot sympify object of type %r' % type(a))
sympy.core.sympify.SympifyError: SympifyError: "cannot sympify object of type <class 'scipy.interpolate._interpolate.interp1d'>"
Although in your case you seem to have a SyntaxError as well
Yes you could use sympy.Piecewise. Consider the following example where we have a unit square, the data-based BC on the left and c=0 on the right:
# make 2D unit square mesh and mark cells and facets
# left boundary is tagged with id 1 and right boundary with id 2
nx = ny = 30
fenics_mesh = f.UnitSquareMesh(nx, ny)
volume_markers = f.MeshFunction("size_t", fenics_mesh, fenics_mesh.topology().dim())
volume_markers.set_all(1)
surface_markers = f.MeshFunction(
    "size_t", fenics_mesh, fenics_mesh.topology().dim() - 1
surface_markers.set_all(0)
class Left(f.SubDomain):
    def inside(self, x, on_boundary):
        return on_boundary and f.near(x[0], 0.0)
class Right(f.SubDomain):
        return on_boundary and f.near(x[0], 1.0)
left = Left()
left.mark(surface_markers, 1)
right = Right()
right.mark(surface_markers, 2)
# FESTIM MODEL
my_model.mesh = F.Mesh(
    fenics_mesh, volume_markers=volume_markers, surface_markers=surface_markers
cm_f = sp.Piecewise(
    (5, F.y < 0.2), (2, F.y < 0.5), (3, F.y < 0.5), (2, F.y < 0.8), (5, True)
    # note instead of having a step function you can work how linear interpolation too
    F.DirichletBC(surfaces=[2], value=0, field=0),
CS = f.plot(my_model.h_transport_problem.u)
plt.colorbar(CS)
Produces:
You could make this more generic by doing something like:
# your data
y = [0, 0.2, 0.5, 0.8, 1]
cm = [5, 2, 3, 2, 5]
list_of_tuples = [(cm_val, F.y < y) for cm_val, y in zip(cm, y[1:])]
list_of_tuples.append((cm[-1], True))
cm_f = sp.Piecewise(*list_of_tuples)
Now if I remember well, this kind of breaks (or at least is extremely long) when you have many more datapoints.
Instead, you could replace the BC in the previous code by:
class InterpolatedExpression(f.UserExpression):
    def __init__(self, f):
        super().__init__()
        self.f = f
    def eval(self, value, x):
        y = x[1]
        value[0] = self.f(y)
    def value_shape(self):
        # scalar value
        return ()
class DirichletBCFromData(F.DirichletBC):
    def __init__(self, surfaces, f, field):
        value = InterpolatedExpression(f)
        super().__init__(surfaces, value, field)
    # override the create_expression method
    def create_expression(self, T):
        self.expression = self.value
# your data
    DirichletBCFromData(surfaces=[1], f=cm_f, field=0),
And this produces:
Here’s what we did:
  • Make our custom DirichletBC class because the one in FESTIM only allows value to be a float or a sympy.Expression. And override the create_expression method
  • Make a fenics.UserExpression class that gets a value from a interp1d object from the y-value.
  • make an instance of the custom DirichletBC and then give this to our FESTIM model
The second approach scales well as we increase the number of datapoints. For example, using 10000 points:
# your data
y = np.linspace(0, 1, num=10000)
cm = 1 + np.sin(2 * np.pi * y)
Produces:
and runs in less than a second on my laptop
Thank you very much, I used the 2nd method and it works perfectly without any time issue.
We could potentially provide native support in FESTIM for this. You are welcome to open a PR!
@ehodille I also took the opportunity to adapt this example to a temperature field from a list of points.
my_model.mesh = F.MeshFromVertices(np.linspace(0, 1))
        super().__init__()
        self.f = f
        self.t = 0
        value[0] = self.f(self.t)
class TFromData(F.Temperature):
        super().__init__(value)
    # override the create_functions method
    def create_functions(self, mesh):
        """Creates functions self.T, self.T_n
            mesh (festim.Mesh): the mesh
        V = f.FunctionSpace(mesh.mesh, "CG", 1)
        self.T = f.Function(V, name="T")
        self.T_n = f.Function(V, name="T_n")
        self.T.assign(f.interpolate(self.expression, V))
        self.T_n.assign(self.T)
# your data
t = np.linspace(0, 10, num=10000)
T = 300 + np.sin(2 * np.pi * t)
T_f = interp1d(t, T)
my_model.T = TFromData(T_f)
    F.DirichletBC(surfaces=[1], value=1, field=0),
    absolute_tolerance=1e-1, relative_tolerance=1e-10, transient=True, final_time=10
my_model.dt = F.Stepsize(0.01)
my_model.exports = [F.DerivedQuantities([F.AverageVolume("T", volume=1)])]
T_t = my_model.exports[-1][0].t
T_values = my_model.exports[-1][0].data
plt.plot(T_t, T_values)
plt.xlabel("Time")
plt.ylabel("Temperature")
Which produces:
This way you could use the experimental T measurement in TDS simulations for instance.
# your data
t = np.linspace(0, 100, num=10000)
T = np.zeros_like(t)  # create array full of zeros
t_tds = 50
T[t < t_tds] = 300  # set values for t < t_tds
ramp = 2
T[t >= t_tds] = 300 + ramp * (t[t >= t_tds] - t_tds)  # set values for t >= t_tds
# interpolate the data
