Attempting Replication of Results in a FESTIM paper
Hi there,
I am attempting to replicate some results from a recent paper entitled entitled “Modeling hydrogen isotope transport behavior in the first wall: role of the bonding region in W-RAFM steel with an improved evaluation of transport coefficients” (see also attached) and I was curious to better understand the results of simulated retention in the first wall. I have attempted to replicate the retention results shown in Figure 8b, but my current outputs (left) are about twice as high as the values shown there (right):
As you can see, each piece is consistently larger in my plot, with the W and bonding regions having ~2.5x increase in retention, and the RAFM having a ~1.3x increase. There are a few areas I think my work could be going astray:
The paper mentions they use an implantation flux of 1.5e21/m^2/s to set the concentration on the plasma-facing edge of the tungsten, according to the expression
c_m = \frac{\phi_{imp} R_p}{D}
where Rp = 5.6e-9 m is the implantation depth and D = D(T) is the arrhenius diffusion coefficient. As described here (see Eq. 16) I am using this to set a Dirichlet boundary condition.
Since the paper doesn’t provide jump frequency or detrapping pre-exponentials k_0 or p_0, respectively, I’m also currently assuming that
for each domain, with lambda = 1.1e-10 and N_surf = 6 across all 3 domains. For p_0, I’m using 1.0e13 across all of them. Therefore, k0 and p0 are both rather rough approximations at the moment, and may be the cause of the discrepancy.
For reference, my full code for the plot above is attached. create_multilayer.py constructs a quasi-1D geometry in two dimensions using the gmsh package:
import gmsh
from dolfinx.io import gmsh as gmshio
from dataclasses import dataclass
@dataclass
class MeshTags:
    """Maps logical names to Gmsh physical group IDs."""
    top_surface: int = 1
    bottom_surface: int = 2
    left_surface: int = 3
    right_surface: int = 4
    left_volume: int = 5
    middle_volume: int = 6
    right_volume: int = 7
    interface_left: int = 8   # between left and middle volumes
    interface_right: int = 9  # between middle and right volumes
def create_3layer_mesh(width_left=0.4, width_middle=0.1,
                       width_right=0.5, height=1.0,
                       mesh_size=0.02):
    Create a 2D mesh of a rectangle split vertically into 3 layers
    (left | middle | right), using Gmsh.
    Returns (dolfinx mesh_data, MeshTags) ready for FESTIM.
    tags = MeshTags()
    total_width = width_left + width_middle + width_right
    x1 = width_left                 # left/middle interface x-coord
    x2 = width_left + width_middle  # middle/right interface x-coord
    gmsh.initialize()
    gmsh.option.setNumber("General.Verbosity", 1)
    gmsh.model.add("three_layer")
    # Corner + interface points
    # Bottom row (y=0), left to right
    p_bl = gmsh.model.occ.addPoint(0,           0, 0, meshSize=mesh_size)
    p_b1 = gmsh.model.occ.addPoint(x1,          0, 0, meshSize=mesh_size)
    p_b2 = gmsh.model.occ.addPoint(x2,          0, 0, meshSize=mesh_size)
    p_br = gmsh.model.occ.addPoint(total_width, 0, 0, meshSize=mesh_size)
    # Top row (y=height), left to right
    p_tl = gmsh.model.occ.addPoint(0,           height, 0, meshSize=mesh_size)
    p_t1 = gmsh.model.occ.addPoint(x1,          height, 0, meshSize=mesh_size)
    p_t2 = gmsh.model.occ.addPoint(x2,          height, 0, meshSize=mesh_size)
    p_tr = gmsh.model.occ.addPoint(total_width, height, 0, meshSize=mesh_size)
    #  Horizontal edges, split per layer so we can tag top/bottom
    bottom_left = gmsh.model.occ.addLine(p_bl, p_b1)
    bottom_middle = gmsh.model.occ.addLine(p_b1, p_b2)
    bottom_right = gmsh.model.occ.addLine(p_b2, p_br)
    top_left = gmsh.model.occ.addLine(p_tl, p_t1)
    top_middle = gmsh.model.occ.addLine(p_t1, p_t2)
    top_right = gmsh.model.occ.addLine(p_t2, p_tr)
    # Vertical edges (outer walls + internal interfaces)
    left_edge = gmsh.model.occ.addLine(p_bl, p_tl)
    interface_left = gmsh.model.occ.addLine(p_b1, p_t1)
    interface_right = gmsh.model.occ.addLine(p_b2, p_t2)
    right_edge = gmsh.model.occ.addLine(p_br, p_tr)
    # Curve loops and surfaces (all CCW)
    left_loop = gmsh.model.occ.addCurveLoop(
        [bottom_left, interface_left, -top_left, -left_edge]
    left_surf = gmsh.model.occ.addPlaneSurface([left_loop])
    middle_loop = gmsh.model.occ.addCurveLoop(
        [bottom_middle, interface_right, -top_middle, -interface_left]
    middle_surf = gmsh.model.occ.addPlaneSurface([middle_loop])
    right_loop = gmsh.model.occ.addCurveLoop(
        [bottom_right, right_edge, -top_right, -interface_right]
    right_surf = gmsh.model.occ.addPlaneSurface([right_loop])
    gmsh.model.occ.synchronize()
    # Physical groups
    # Volumes (2D surfaces)
    gmsh.model.addPhysicalGroup(2, [left_surf], tag=tags.left_volume)
    gmsh.model.setPhysicalName(2, tags.left_volume, "left_volume")
    gmsh.model.addPhysicalGroup(2, [middle_surf], tag=tags.middle_volume)
    gmsh.model.setPhysicalName(2, tags.middle_volume, "middle_volume")
    gmsh.model.addPhysicalGroup(2, [right_surf], tag=tags.right_volume)
    gmsh.model.setPhysicalName(2, tags.right_volume, "right_volume")
    # Outer boundaries (grouped across layers where appropriate)
        1, [top_left, top_middle, top_right], tag=tags.top_surface
    gmsh.model.setPhysicalName(1, tags.top_surface, "top_surface")
        1, [bottom_left, bottom_middle, bottom_right], tag=tags.bottom_surface
    gmsh.model.setPhysicalName(1, tags.bottom_surface, "bottom_surface")
    gmsh.model.addPhysicalGroup(1, [left_edge], tag=tags.left_surface)
    gmsh.model.setPhysicalName(1, tags.left_surface, "left_surface")
    gmsh.model.addPhysicalGroup(1, [right_edge], tag=tags.right_surface)
    gmsh.model.setPhysicalName(1, tags.right_surface, "right_surface")
    # Internal interfaces
    gmsh.model.addPhysicalGroup(1, [interface_left], tag=tags.interface_left)
    gmsh.model.setPhysicalName(1, tags.interface_left, "interface_left")
    gmsh.model.addPhysicalGroup(1, [interface_right], tag=tags.interface_right)
    gmsh.model.setPhysicalName(1, tags.interface_right, "interface_right")
    # Generate mesh & import into dolfinx
    model_rank = 0
    gmsh.model.mesh.generate(2)
    mesh_data = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank)
    gmsh.finalize()
    return mesh_data, tags
Shen2026Replication.py was made with FESTIM 2.0, specifically version 2.0b2.post2 (which I believe is the most current). It is pasted below:
import dolfinx, ufl
from scipy.constants import k, e
from FESTIM.create_multilayer import create_3layer_mesh
# Physical constants / global configuration
k_B = k / e                   # Boltzmann constant [eV/K]
T_sim = 823.0                 # FW temperature [K]  (section 4.2)
# Implantation (eq. 17, section 2.3)
phi_imp = 1.5e21              # [m^-2 s^-1]
R_p = 5.6e-9                  # [m]
# W diffusivity (intrinsic, values from section 4 of paper)
D0_W, ED_W = 2.40e-7, 0.20    # [m^2/s], [eV]
# Surface concentration approximation for implantation (eq. 17): c_m = phi*R_p/D
D_W_at_T = D0_W * np.exp(-ED_W / (k_B * T_sim))
c_surface_W = phi_imp * R_p / D_W_at_T
# Layer thicknesses for the FW (1D model, section 4.2): W | bond | RAFM
L_W      = 2.0e-3             # 2 mm  W armour
L_BOND   = 0.1e-3             # 0.1 mm bonding region
L_RAFM   = 20.0e-3            # 20 mm  RAFM structural steel
HEIGHT   = 0.1e-3             # height of slab => TotalVolume ~ atoms/m^2 of FW
# Atomic site densities (used to build k_0 = D_0 / (lambda^2 * n_surf * N_L))
LAMBDA   = 1.1e-10            # jump distance [m]
N_SURF   = 6.0                # coordination number
N_L_W    = 6.3e28             # W atomic density [m^-3] (paper uses 6.3e28)
N_L_RAFM = 8.4e28             # Fe (bcc) atomic density [m^-3]
N_L_BOND = 7.0e28             # intermediate, used for the bonding region
# Detrapping pre-exponential--assumed for now
P0_TRAP  = 1.0e13             # [s^-1]
# Trap parameters from the paper
# Table 4 -- pure W
TRAPS_W = [
    {"E_p": 1.5, "n_t": 9.0e22},
    {"E_p": 1.7, "n_t": 1.5e23},
    {"E_p": 2.9, "n_t": 1.0e23},
# Table 2 -- RAFM steel
TRAPS_RAFM = [
    {"E_p": 1.4, "n_t": 6.0e22},
    {"E_p": 2.2, "n_t": 8.0e21},
    {"E_p": 2.8, "n_t": 3.6e22},
# Table 5 -- bonding regions (one entry per joint type)
TRAPS_BOND_WRAFM = [
    {"E_p": 1.0, "n_t": 1.0e24},
    {"E_p": 1.4, "n_t": 5.0e23},
    {"E_p": 2.9, "n_t": 3.0e22},
TRAPS_BOND_WNiRAFM = [
    {"E_p": 1.0, "n_t": 5.5e24},
    {"E_p": 1.5, "n_t": 1.0e23},
    {"E_p": 2.4, "n_t": 5.0e24},
TRAPS_BOND_WCuRAFM = [
    {"E_p": 0.9, "n_t": 2.0e24},
# Material definitions (diffusivity + Sievert solubility).
# Diffusivities are the quasi-intrinsic values from the paper (eqs. 24-27).
# In festim 2.0, HydrogenTransportProblemDiscontinuous needs K_S to evaluate
# the chemical-potential continuity condition at the interfaces (paper eq. 16):
#       c_m^- / K_S^- = c_m^+ / K_S^+
# Eq. 29 of the paper uses the series-resistor formula L/D = sum(L_i / D_i),
# which assumes concentration continuity at the interfaces. If my understanding
# is correct, this is equivalent to using a common K_S for all three layers.
# We choose an arbitrary value for uniform K_s. It shouldn't affect the result
#  but FESTIM needs a concrete number.
K_S_0_COMMON = 1.0e24   # at/m^3/Pa^0.5 (arbitrary, uniform across layers)
E_K_S_COMMON = 0.0      # eV           (arbitrary, uniform across layers)
_sol = dict(K_S_0=K_S_0_COMMON, E_K_S=E_K_S_COMMON, solubility_law="sievert")
# Diffusivity parameters (taken from paper)
W_MAT_PARAMS    = dict(D_0=2.40e-7, E_D=0.20, **_sol)
RAFM_MAT_PARAMS = dict(D_0=1.95e-7, E_D=0.12, **_sol)
# Bonding regions (eqs. 25-27 for D; same K_S as everything else)
BOND_PARAMS_WRAFM = dict(D_0=2.40e-7, E_D=0.20, **_sol)
BOND_PARAMS_WNi   = dict(D_0=3.80e-8, E_D=0.28, **_sol)
BOND_PARAMS_WCu   = dict(D_0=1.45e-9, E_D=0.13, **_sol)
def k0_from_D0(D0, N_L):
    Trapping pre-exponential from the standard McNabb-Foster form:
        k = D0 / (lambda^2 * n_surf * N_L) * exp(-E_D / kT)
    return D0 / ((LAMBDA**2) * N_SURF * N_L)
# Integrate a dolfinx Function over its (sub)mesh to get total retention
def _integrate_solution(dolfinx_fn):
    mesh = dolfinx_fn.function_space.mesh
    form = dolfinx.fem.form(dolfinx_fn * ufl.dx)
    local = dolfinx.fem.assemble_scalar(form)
    return mesh.comm.allreduce(local, op=MPI.SUM)
# Core simulation routine
def run_case(case_name, bond_params=None, bond_traps=None, N_L_bond=N_L_BOND):
    Build and solve a FW diffusion-trapping model for one configuration.
    Parameters:
        case_name : str
            Label used in plot / printouts.
        bond_params : dict or None
            D_0/E_D for the middle (bonding) layer.  If None, the middle layer
            gets the W properties and NO traps.
        bond_traps : list of dicts or None
            Trap parameters for the bonding region.  Ignored if bond_params is None.
        N_L_bond : float
            Lattice site density used to compute k_0 for the bonding region.
    Returns:
        dict with per-layer retention (atoms / m^2 of FW surface).
    print(f"\n{'-'*15}\nRunning case: {case_name}\n{'-'*15}")
    # Use a quasi-1D two-dimensional simulation of the layer geometry
    mesh_size = L_BOND / 10.0       # resolves bond layer without too much overhead.
    mesh_data, tags = create_3layer_mesh(
        width_left=L_W,
        width_middle=L_BOND,
        width_right=L_RAFM,
        height=HEIGHT,
        mesh_size=mesh_size,
    festim_mesh = F.Mesh(mesh_data.mesh)
    # Model + mesh tags (these come directly from gmsh via create_3layer_mesh)
    model = F.HydrogenTransportProblemDiscontinuous()
    model.mesh = festim_mesh
    model.facet_meshtags = mesh_data.facet_tags
    model.volume_meshtags = mesh_data.cell_tags
    # Materials & volume/surface subdomains
    tungsten = F.Material(name="tungsten", **W_MAT_PARAMS)
    # For the "no bonding region" baseline we give the middle layer W
    # properties (same as its left neighbour) and no traps, so it's physically
    # invisible but still lets us reuse the same 3-layer mesh for all cases.
    if bond_params is None:
        bond_mat_params = W_MAT_PARAMS
        bond_traps_effective = []
        bond_mat_params = bond_params
        bond_traps_effective = bond_traps or []
    bond_mat = F.Material(name="bonding_region", **bond_mat_params)
    rafm     = F.Material(name="rafm_steel",    **RAFM_MAT_PARAMS)
    vol_W    = F.VolumeSubdomain(id=tags.left_volume,   material=tungsten)
    vol_bond = F.VolumeSubdomain(id=tags.middle_volume, material=bond_mat)
    vol_RAFM = F.VolumeSubdomain(id=tags.right_volume,  material=rafm)
    # Plasma-facing side = left edge of the W layer.
    # Coolant / vacuum side = right edge of the RAFM layer.
    surf_left  = F.SurfaceSubdomain(id=tags.left_surface)   # W surface
    surf_right = F.SurfaceSubdomain(id=tags.right_surface)  # RAFM surface
    model.subdomains = [vol_W, vol_bond, vol_RAFM, surf_left, surf_right]
    # Interfaces between the three layers (chemical potential continuity).
    # A large penalty keeps the jump condition well-enforced; see here:
    # https://festim.discourse.group/t/interface-condition-issue-in-multi-material-diffusion-with-mixed-solubility-laws/158
    model.interfaces = [
        F.Interface(
            id=tags.interface_left,
            subdomains=(vol_W, vol_bond),
            penalty_term=1e20,
        F.Interface(
            id=tags.interface_right,
            subdomains=(vol_bond, vol_RAFM),
            penalty_term=1e20,
    model.surface_to_volume = {surf_left: vol_W, surf_right: vol_RAFM}
    # Species: 1 mobile T + one trapped-T immobile species per (layer, trap)
    H = F.Species("T")
    H.subdomains = [vol_W, vol_bond, vol_RAFM]
    all_species   = [H]
    all_reactions = []
    # Per-layer bookkeeping of trapped species for the retention integrals.
    layer_to_trapped = {vol_W: [], vol_bond: [], vol_RAFM: []}
    def add_traps(volume, traps_list, D0_mat, ED_mat, N_L_mat, tag):
        """Register trap reactions for one layer."""
        k0 = k0_from_D0(D0_mat, N_L_mat)
        for i, trap in enumerate(traps_list):
            trapped = F.Species(f"trap_{tag}_{i}", mobile=False)
            trapped.subdomains = [volume]
            empty = F.ImplicitSpecies(n=trap["n_t"], others=[trapped])
            all_species.append(trapped)
            layer_to_trapped[volume].append(trapped)
            all_reactions.append(
                F.Reaction(
                    reactant=[H, empty],
                    product=[trapped],
                    k_0=k0,
                    E_k=ED_mat,
                    p_0=P0_TRAP,
                    E_p=trap["E_p"],
                    volume=volume,
    add_traps(vol_W, TRAPS_W, W_MAT_PARAMS["D_0"], W_MAT_PARAMS["E_D"], N_L_W, "W")
    add_traps(vol_bond, bond_traps_effective, bond_mat_params["D_0"], bond_mat_params["E_D"], N_L_bond, "bond")
    add_traps(vol_RAFM, TRAPS_RAFM, RAFM_MAT_PARAMS["D_0"], RAFM_MAT_PARAMS["E_D"], N_L_RAFM, "RAFM")
    model.species = all_species
    model.reactions = all_reactions
    # Boundary conditions & temperature
    model.temperature = T_sim
        F.FixedConcentrationBC(subdomain=surf_left,  species=H, value=c_surface_W),
        F.FixedConcentrationBC(subdomain=surf_right, species=H, value=0.0),
    # Solver settings --> steady state. At steady state the trapping reactions
    # equilibrate to the Oriani relation (trap occupancy determined locally by c_m)
        atol=1e-10,
        rtol=1e-10,
        max_iterations=1000,
    # Run
    # Post-process: per-layer retention = integral of (c_m + sum c_trapped)/area
    results = {}
    for volume, label in [(vol_W, "W"), (vol_bond, "bond"), (vol_RAFM, "RAFM")]:
        mobile_sol = H.subdomain_to_post_processing_solution[volume]
        mob_int = _integrate_solution(mobile_sol)
        trap_int = 0.0
        for tsp in layer_to_trapped[volume]:
            tsp_sol = tsp.subdomain_to_post_processing_solution[volume]
            trap_int += _integrate_solution(tsp_sol)
        # Divide by slab height -> atoms / m^2 of FW surface
        results[label] = (mob_int + trap_int) / HEIGHT
        print(f"  {label:4s}: mobile = {mob_int/HEIGHT:.3e},"
              f"  trapped = {trap_int/HEIGHT:.3e}  -> "
              f"total = {results[label]:.3e}  atoms/m^2")
    results["total"] = sum(results[l] for l in ("W", "bond", "RAFM"))
    return results
# Run the four FW configurations of figure 8(b)
if __name__ == "__main__":
    cases = {}
    cases["W-RAFM"] = run_case("W-RAFM (no bonding region)", bond_params=None)
    cases["W-bond-RAFM"] = run_case("W-bonding-RAFM",
                                    bond_params=BOND_PARAMS_WRAFM,
                                    bond_traps=TRAPS_BOND_WRAFM)
    cases["W-Ni-RAFM"] = run_case("W-Ni-RAFM",
                                  bond_params=BOND_PARAMS_WNi,
                                  bond_traps=TRAPS_BOND_WNiRAFM)
    cases["W-Cu-RAFM"] = run_case("W-Cu-RAFM",
                                  bond_params=BOND_PARAMS_WCu,
                                  bond_traps=TRAPS_BOND_WCuRAFM)
    # Plot figure 8(b) --> stacked bar w/ W (bottom) + bonding (middle) + RAFM (top)
    labels = list(cases.keys())
    W_vals    = np.array([cases[c]["W"]    for c in labels]) / 1e20
    bond_vals = np.array([cases[c]["bond"] for c in labels]) / 1e20
    rafm_vals = np.array([cases[c]["RAFM"] for c in labels]) / 1e20
    fig, ax = plt.subplots(figsize=(7, 5))
    x = np.arange(len(labels))
    width = 0.55
    ax.bar(x, W_vals, width, label="W", color="#d9bc2c")
    ax.bar(x, bond_vals, width, bottom = W_vals, label="Bond region", color="#c79a3a")
    ax.bar(x, rafm_vals, width, label="RAFM",
           bottom = W_vals+ bond_vals, color="#6e4a1a")
    ax.set_xticks(x)
    ax.set_xticklabels(labels)
    ax.set_ylabel(r"Retention (10$^{20}$ T m$^{-2}$)")
    ax.set_title("Reproduction of Shen et al. (2026), Fig. 8(b)")
    ax.legend(loc="upper left")
    ax.grid(axis="y", linestyle=":", alpha=0.5)
    totals = W_vals + bond_vals + rafm_vals
    for xi, tot in zip(x, totals):
        ax.text(xi, tot + 0.2, f"{tot:.1f}", ha="center", va="bottom", fontsize=9)
    plt.tight_layout()
    # Summary table
    print("\n\nSummary (retention in 10^20 atoms/m^2):")
    print(f"{'case':15s}  {'W':>8s}  {'bond':>10s}  {'RAFM':>8s}  {'total':>8s}")
    for c in labels:
        r = cases[c]
        print(f"{c:15s}  {r['W']/1e20:8.2f}  {r['bond']/1e20:10.2e}  "
              f"{r['RAFM']/1e20:8.2f}  {r['total']/1e20:8.2f}")
Any thoughts would be greatly appreciated.
Thanks for sharing. Bit hard to parse a big script like this but here are a few thoughts:
  • why make a 2D model? It would be a lot simpler in 1D
  • homogeneous solubility: you mention in the comment that it shouldn’t affect the results. Why? Are the traps saturated in the original paper? If not then the concentration of mobile particles will play a role, which means the solubility is not negligible at all
Thanks for your thoughts! In responses to your questions:
  1. I agree 1D would be a lot simpler. Really the only reason I went with 2D was because I was interested in getting a bit of practice on how to use gmsh.
  2. Yes; as far as I can tell the traps are saturated in the original paper and provide the overwhelming majority of the hydrogen retention. In the version of the script posted above, changing the solubility \pm 2 orders of magnitude from what I have it changes the final retention results by <10%. I should’ve been a bit more careful with my wording in that comment :slight_smile:
The first author (Xin Shen) responded to my email about this and provided a script that they used, which was very helpful in understanding the discrepancies between their work and mine:
  1. While they initially agreed with my interpretation that they assume that the solubility is an arbitrary constant across the 3 materials, the script that they provided proved otherwise–they do indeed have different solubilities across all 3 material regions.
  2. In the paper, they say that k=k_0 \exp(-\frac{E_D}{RT}) (which has a typo btw–it should be k_B in the denominator and not R). I took E_D to mean the diffusion energy that they provided for each material, but they actually use unique values of this energy, E_k, that varied across different traps (this wasn’t mentioned in the manuscript).
    \quad a) I need to confirm this for certain, but I believe they used they same set of E_k across all 3 bonding region materials.
    \quad b) They confirmed k_0 is set to a constant of 1e-17 across all materials, and not the approximation that I had above.
  3. There were a few small rounding/truncating issues here and there when comparing the data in the paper to the data in their script. Nothing major, but a few energies were 0.01-0.05 eV different in their script from what it actually was in the paper. I tweaked my values to be in line with their script values.
Applying all of these changes to my main script gives me the graph below, which I think more or less replicates their original! Updated script is also attached for what it’s worth.
import dolfinx, ufl
from create_multilayer import create_3layer_mesh
R_p = 5.6e-9                  # [m]
D_W_at_T = D0_W * np.exp(-0.21 / (k_B * T_sim))       # --> NOTE: they use 0.21eV instead of 0.20 here?
L_BOND   = 0.102e-3           # 0.102 mm bonding region --> NOTE: corrected based on XS's script, was 0.1mm
# (De)trapping pre-exponentials
k0_TRAP = 1e-17               # --> NOTE: different from my approximation
TRAPS_W = [ # Table 4 -- pure W
    {"E_p": 1.5, "E_k": 0.2, "n_t": 9.0e22},    # --> NOTE: E_k is never given/mentioned in the paper!
    {"E_p": 1.7, "E_k": 0.32, "n_t": 1.5e23},
    {"E_p": 2.9, "E_k": 1.2, "n_t": 1.0e23},
TRAPS_RAFM = [ # Table 2 -- RAFM steel
    {"E_p": 1.4, "E_k": 0.4, "n_t": 6.0e22},
    {"E_p": 2.2, "E_k": 0.8, "n_t": 8.0e21},
    {"E_p": 2.82, "E_k": 1.22, "n_t": 3.6e22},   # --> NOTE: corrected based on XS's script.
]                                                # Their paper says E_p = 2.8 ev.
# Table 5 -- bonding regions. All 3 regions are given the same set of E_k (confirmation of this needed)
    {"E_p": 1.0, "E_k": 0.15, "n_t": 1.0e24},
    {"E_p": 1.4, "E_k": 0.6, "n_t": 5.0e23},
    {"E_p": 2.9, "E_k": 0.9, "n_t": 3.0e22},
    {"E_p": 1.0, "E_k": 0.15, "n_t": 5.5e24},
    {"E_p": 1.5, "E_k": 0.6, "n_t": 1.0e23},
    {"E_p": 2.4, "E_k": 0.9, "n_t": 5.0e24},
    {"E_p": 0.9, "E_k": 0.15, "n_t": 2.0e24},
    {"E_p": 2.35, "E_k": 0.9, "n_t": 5.0e24},    # --> NOTE: corrected based on XS's script.
]                                                 # Their paper says E_p=2.4.
# --> NOTE: Despite XS initially agreeing that all solubilities were uniform, they aren't.
# Rewrote the material dicts with their solubility values.
W_MAT_PARAMS    = dict(D_0=2.40e-7, E_D=0.20, K_S_0=1.87e24, E_K_S=1.04)
RAFM_MAT_PARAMS = dict(D_0=1.95e-7, E_D=0.12, K_S_0=2.41e23, E_K_S=0.30)
# Bonding regions (eqs. 25-27 for D)
BOND_PARAMS_WRAFM = dict(D_0=2.40e-7, E_D=0.20, K_S_0=7e23, E_K_S=0.6)
BOND_PARAMS_WNi   = dict(D_0=3.80e-8, E_D=0.28, K_S_0=7e23, E_K_S=0.6)
BOND_PARAMS_WCu   = dict(D_0=1.45e-9, E_D=0.13, K_S_0=7e23, E_K_S=0.6)
def run_case(case_name, bond_params=None, bond_traps=None):
    Parameters:
        case_name : str
    Returns:
        width_left=L_W,
        width_right=L_RAFM,
        height=HEIGHT,
    # properties (same as its left neighbor) and no traps, so it's physically
    # invisible but still lets us re-use the same 3-layer mesh for all cases.
        F.Interface(
            penalty_term=1e20,
        F.Interface(
            penalty_term=1e20,
    H = F.Species("T")
    all_species   = [H]
    all_reactions = []
    def add_traps(volume, traps_list, ED_mat, tag):
            try:
                E_k_TRAP=trap["E_k"]
            except:
                E_k_TRAP=ED_mat
                F.Reaction(
                    product=[trapped],
                    k_0=k0_TRAP,
                    E_k=E_k_TRAP,         # --> NOTE: Despite the paper saying E_k = E_D, XS's script doesn't do this.
                    p_0=P0_TRAP,
                    E_p=trap["E_p"],
                    volume=volume,
    add_traps(vol_W, TRAPS_W, W_MAT_PARAMS["E_D"], "W")
    add_traps(vol_bond, bond_traps_effective, bond_mat_params["E_D"], "bond")
    add_traps(vol_RAFM, TRAPS_RAFM, RAFM_MAT_PARAMS["E_D"], "RAFM")
        atol=1e-10,
        rtol=1e-10,
    # Run
    # Post-process: areal retention = integral of (c_m + sum c_trapped)/height
    results = {}
        trap_int = 0.0
    return results
    cases = {}
    width = 0.55
    ax.set_xticks(x)
    plt.tight_layout()
I believe @xinshen is on the discourse too!
Hi there,
Sorry for the delays.
Yes there are 0.01-0.05 eV differences between my script and the manuscript, however the discrepancy is just from making all the values with the same number of digits.
