2d simulation breaks when introducing traps
Hi,
I am trying to model 2d steel square inside another piece of steel, with traps in the inner piece of steel only. Initially, hydrogen is in inner steel. The code below works ok, but as soon as I uncomment the trap lines, something strange happens: at time = 0, nonzero concentration of solute is at the interface between steels only!
Could you please explain what is wrong with my code?
Best wishes,
Mikhail
from fenics import *
from festim import x, y, z
import sympy
import math
# GEOMETRY AND MESH
width = 1
height = 1
border_thickness = 0.1
nx, ny = 21, 21
mesh = RectangleMesh(Point(0, 0), Point(width, height), nx, ny)
# MARK VOLUMES
volume_markers = MeshFunction(“size_t”, mesh, mesh.topology().dim())
volume_markers.set_all(2)
plot(volume_markers, title=“Volume Markers (1=steel1, 2=steel2)”)
inner_metal = CompiledSubDomain(
“x[0] > x_min && x[0] < x_max && x[1] > y_min && x[1] < y_max”,
x_min=border_thickness,
x_max=width - border_thickness,
y_min=border_thickness,
y_max=height - border_thickness
inner_metal.mark(volume_markers, 1)
model.mesh = F.Mesh(mesh=mesh, volume_markers=volume_markers)
# MATERIALS
steel1 = F.Material(
id = 1,
D_0 = 1e-16, #m2/s
E_D = 0, #eV
steel2 = F.Material(
id = 2,
D_0 = 1E-15, #m2/s
E_D = 0, #eV
model.materials = [steel1, steel2]
# TEMPERATURE
model.T = 300
# INITIAL CONDITIONS
model.initial_conditions = [
F.InitialCondition(
    field="solute",
    value=1e26 \* sympy.Piecewise(
        (1, (x > border_thickness) & (x < width - border_thickness) &
            (y > border_thickness) & (y < height - border_thickness)),
        (0, True)
# SURFACE MARKERS
surface_markers = MeshFunction(“size_t”, mesh, mesh.topology().dim() - 1)
surface_markers.set_all(0)
steel1_boundary = CompiledSubDomain(
“near(x[0], x_min) || near(x[0], x_max) || near(x[1], y_min) || near(x[1], y_max)”,
steel2_boundary = CompiledSubDomain(
“on_boundary”,
steel1_boundary.mark(surface_markers, 1)
steel2_boundary.mark(surface_markers, 2)
model.mesh.surface_markers = surface_markers
SS316L_density = 8.55e28
#TRAPS
#SS316L_trap = F.Trap(
# k_0 = 3.82e-7 / ((5.66e-10)**2 * 6 * SS316L_density),
# E_k = 0.16,
# p_0 = 1e13,
# E_p = 0.5,
# density = 6.08e25,
# materials = [steel1]
#model.traps = [SS316L_trap]
# BOUNDARY CONDITIONS
F.DirichletBC(field = 0,
              value = 0,
              surfaces = \[2\]),
#EXPORTS
results_folder = “TWO_DIMENSION_PERMEATION”
model.exports = [
F.XDMFExport(
    field="solute",
    filename=results_folder + "/hydrogen_concentration.xdmf",
    checkpoint=False,
# SETTINGS
absolute_tolerance = 1e16,
relative_tolerance = 1e-8,
final_time= 1e3,
# TIMESTEP
model.dt = F.Stepsize(
initial_value=1,
dt_min=1e-5,
max_stepsize=1e3,
P.S. This is FESTIM1
Hi @miklavrent could you provide some screenshots to illustrate your issue? The code block isn’t formatted properly so it’s not easy to copy paste
Thank you for your reply! It looks like there are several unexpected backslashes in the code, perhaps it’ll work if you delete them? Anyway, I attach two screenshots showing initial mobile distribution with and without the trap part.
Best wishes,
Mikhail
If you look at the colour bar, the first screenshot shows a negative value in the inner square. The red strip is an “overshoot”. This seems like a typical Gibb’s phenomenon issue related to the mesh.
Basically you are trying to approximate very sharp gradients with too few cells. Things to consider:
  • refining the mesh
  • use discontinuous finite elements (DG) for the trap concentration
To get an idea of the refinement level you need, you may want to setup a 1D simulation an play with the refinement there. By the way, are you sure your problem isn’t a 1D problem?
Thank you Remi, I’ll try to refine the mesh and/or use DG. Indeed this looks like a 1D problem, but it’s because I simplified it to bring as close to MWE as possible.
@miklavrent what’s the status of this? can we close this?
Hi Remi, yes please close! I remember resolving this problem by introducing finer mesh in a border region between two pieces of steel.
