Note: please format your code correctly with triple signs ``` and not quote blocks >. I modified your post
I reproduce the error
File "/home/remidm/FESTIM/mwe.py", line 40, in <module>
File "/home/remidm/FESTIM/src/festim/hydrogen_transport_problem.py", line 1861, in run
self.post_processing()
File "/home/remidm/FESTIM/src/festim/hydrogen_transport_problem.py", line 1708, in post_processing
raise NotImplementedError(
NotImplementedError: Export type <class 'festim.exports.vtx.VTXTemperatureExport'> not implemented
This is because we have not yet implemented the VTXTemperatureExport support in the HydrogenTransportProblemDiscontinuous class.
Now in your case you can manually export the temperature at the end of the simulation (or maybe even just after initialise()
my_model = F.HydrogenTransportProblemDiscontinuous()
mat = F.Material(
D_0=1,
E_D=0,
vol = F.VolumeSubdomain1D(id=1, borders=[0, 1], material=mat)
my_model.subdomains = [vol]
my_model.mesh = F.Mesh1D(np.linspace(0, 1, 100))
my_model.species = [F.Species("H", subdomains=[vol])]
# Had to change this because it only makes sense to export the temperature
# to a file if it's a function of x and not a constant.
my_model.temperature = lambda x: 700 + 100 * x[0]
my_model.settings = F.Settings(transient=False, atol=1e-9, rtol=1e-9)
# temp_export = F.VTXTemperatureExport(
# filename="mwe_exports/temperature.bp",
# my_model.exports = [temp_export]
from dolfinx import fem
from dolfinx.io import VTXWriter
from pathlib import Path
assert isinstance(my_model.temperature_fenics, fem.Function), (
f"Temperature field is not a fenics function, got {type(my_model.temperature_fenics)}"
with VTXWriter(
MPI.COMM_WORLD,
Path("mwe_exports/temperature.bp"),
"BP4",
) as writer:
writer.write(0.0)
