How do I output results at time zero, please? adding 0 to this line does not seem to work:
F.TXTExport(
field=“solute”,
times=[0,1,2,3,1000],
filename=results_folder + “/mobile_concentration.txt”,
Hi @HelenS ,
Quick tip: you can format your code using three ` signs like this
F.TXTExport(
field=“solute”,
It makes it easier for us to read your code ![]()
It is not possible to export the field at time 0 at the moment.
Hi Helen,
I have been giving this some thoughts and this is how you can hack your way to export everything at t=0s.
In this example (adapted from task 1 of the workshop), there is an initial condition of c=1e21 H/m3 everywhere in the 1D domain.
The concentration on the surfaces is set to zero.
my_model.mesh = F.MeshFromVertices(vertices=np.linspace(0, 7e-6, num=1001))
my_model.materials = F.Material(id=1, D_0=1e-7, E_D=0.2)
my_model.T = 300
F.DirichletBC(surfaces=[1, 2], value=0, field=0) # H/m3/s
my_model.initial_conditions = [F.InitialCondition(field=0, value=1e21)]
absolute_tolerance=1e10, relative_tolerance=1e-10, final_time=2 # s
results_folder = "results"
xdmf_export = F.XDMFExport(
field="solute",
filename=results_folder + "/hydrogen_concentration.xdmf",
checkpoint=False, # needed in 1D
txt_export = F.TXTExport(
field="solute",
times=[0.0, 0.1, 0.2, 0.5, 1],
filename=results_folder + "/mobile_concentration.txt",
my_model.exports = [xdmf_export, txt_export]
my_model.dt = F.Stepsize(0.05, milestones=[0.1, 0.2, 0.5, 1]) # s
# little hack to export for t=0s after calling .initialise()
my_model.exports.final_time = my_model.settings.final_time
my_model.h_transport_problem.u.assign(my_model.h_transport_problem.u_n)
my_model.run_post_processing()
# run the simulation
# plot solution
data = np.genfromtxt(
results_folder + "/mobile_concentration.txt", skip_header=1, delimiter=","
for i, t in enumerate(txt_export.times):
plt.plot(data[:, 0], data[:, i + 1], label=f"t={t:.1f}s")
plt.xlabel("x (m)")
plt.ylabel("Mobile concentration (H/m3)")
This produces the following plot:
