Error defining time-dependent sources using dolfinx0.10.0
Hello everyone,
I am currently working with hisp and PFC-Tritium-Transport in order to determine tritium inventory in ITER. I am running a custom version of hisp (AdriaLlealS/hisp at fix-b-bins) using the festim-fenicsx branch of festim and dolfinx 0.10.0 version. I managed to run simulations without defining sources, and fixing the surface concentration of mobile species (using the implantation approximation Theory — FESTIM Documentation ).
However, when I try to define sources and use surface reactions as BCs (or setting surface concentrations to zero) I get an error that I haven’t been able to solve.
Here is a simple script relying only on festim replicating the error:
```python
import ufl
import festim as F  # fenicsx branch (DOLFINx 0.10)
from dolfinx.fem.function import Constant
import numpy.typing as npt
class PulsedSource(F.ParticleSource):
    def __init__(self, flux, distribution, volume, species):
        self.flux = flux
        self.distribution = distribution
        super().__init__(None, volume, species)
    @property
    def time_dependent(self):
        return True
    def create_value_fenics(self, mesh, temperature, t: Constant):
        self.flux_fenics = F.as_fenics_constant(self.flux(float(t)), mesh)
        x = ufl.SpatialCoordinate(mesh)
        self.distribution_fenics = self.distribution(x)
        self.value_fenics = self.flux_fenics * self.distribution_fenics
    def update(self, t: float):
        self.flux_fenics.value = self.flux(t)
my_model = F.HydrogenTransportProblem()
folder = "outputs"
exports = True
L = 5e-4
def graded_vertices(L, h0, r):
    xs = [0.0]; h = h0
    while xs[-1] + h < L:
        xs.append(xs[-1] + h); h *= r
    if xs[-1] < L:
        xs.append(L)
    return np.array(xs)
vertices_graded = graded_vertices(L=L, h0=L/12e9, r=1.01)
my_model.mesh = F.Mesh1D(vertices_graded)
k_B = 8.617333262e-5
D_0 = 4.1e-7
E_D = 0.2
tungsten = F.Material(D_0=D_0, E_D=E_D, name="tungsten")
w_subdomain = F.VolumeSubdomain1D(id=1, borders=[0, L], material=tungsten)
inlet = F.SurfaceSubdomain1D(id=1, x=0.0)
outlet = F.SurfaceSubdomain1D(id=2, x=L)
my_model.subdomains = [w_subdomain, inlet, outlet]
mobile_D = F.Species("D")
mobile_T = F.Species("T")
my_model.species = [mobile_D, mobile_T]
T_surface = 600.0
def temperature(t): return T_surface
my_model.temperature = temperature
implantation_range = 3e-9
width = 1e-9
def gaussian_distribution(x: npt.NDArray, mean: float, width: float) -> ufl.core.expr.Expr:
    return ufl.exp(-((x[0] - mean)**2)/(2*width**2)) / (ufl.sqrt(2*ufl.pi*width**2))
pulse_period = 100.0
pulse_on_time = 50.0
Gamma_ion_D_peak = 1e19
Gamma_ion_T_peak = 5e18
def square_pulse(t, peak):
    try:
        tau = float(t) % pulse_period
    except Exception:
        tau = t
    return peak if (0.0 <= tau < pulse_on_time) else 0.0
F_D = lambda t: square_pulse(t, Gamma_ion_D_peak)
F_T = lambda t: square_pulse(t, Gamma_ion_T_peak)
dist_fn = lambda x: gaussian_distribution(x, implantation_range, width)
my_model.sources = [
    PulsedSource(flux=F_D, distribution=dist_fn, volume=w_subdomain, species=mobile_D),
    PulsedSource(flux=F_T, distribution=dist_fn, volume=w_subdomain, species=mobile_T),
    F.FixedConcentrationBC(subdomain=inlet, value=0.0, species="D"),
    F.FixedConcentrationBC(subdomain=inlet, value=0.0, species="T"),
if exports:
        F.VTXSpeciesExport(f"{folder}/mobile_D.bp", field=mobile_D),
        F.VTXSpeciesExport(f"{folder}/mobile_T.bp", field=mobile_T),
        F.VTXTemperatureExport(f"{folder}/temperature.bp"),
quantities = {}
for sp in my_model.species:
    total = F.TotalVolume(field=sp, volume=w_subdomain)
    my_model.exports.append(total)
    quantities[sp.name] = total
final_time = 1000.0
    atol=1e10,
    rtol=1e-10,
    final_time=final_time,
    max_iterations=50,
my_model.settings.stepsize = F.Stepsize(initial_value=1e-3)
I included the PulsedSource class of hisp in the script. The error message hat I get is:
File “/home/ITER/llealsa/AdriaLlealS/test.py”, line 188, in
File “/home/ITER/llealsa/.local/lib/python3.11/site-packages/festim/hydrogen_transport_problem.py”, line 326, in initialise
self.create_formulation()
File “/home/ITER/llealsa/.local/lib/python3.11/site-packages/festim/hydrogen_transport_problem.py”, line 871, in create_formulation
source.value.fenics_object
TypeError: unsupported operand type(s) for *: ‘NoneType’ and ‘Indexed’
I’ve been trying to fix this issue but haven’t had any success.
Thank you very much in advance and best regards,
Adrià
Hi @AdriaLlealS, I think your code block formatting needs fixing.
I’ll look into this issue
It’s very hard for me to run your code because of the formatting, can you try and fix it before I run it?
Yes of course, apologies for that. I think it should be easier now.
I managed to reproduce your error with the following minimal working example (only 60 line long!)
import ufl
print(F.__version__)
        self.flux = flux
    @property
        return True
L = 5e-4
my_model.mesh = F.Mesh1D(np.linspace(0, L, 50))
tungsten = F.Material(D_0=1, E_D=0, name="tungsten")
my_model.subdomains = [w_subdomain]
my_model.species = [mobile_D]
my_model.temperature = 600.0
    PulsedSource(
        flux=1, distribution=lambda x: 1, volume=w_subdomain, species=mobile_D
final_time = 1000.0
    atol=1e10,
    rtol=1e-10,
    max_iterations=50,
@jhdark I believe this is because ParticleSource is now expecting a Value object. I’ll dig into this more
@AdriaLlealS the issue is that you pass None as the value argument when initialising the particle source parent class.
Instead, you can do the following:
        self.flux = flux
        value = lambda x, t: self.flux(t) * self.distribution(x)
        super().__init__(value, volume, species)
L = 1
boundary_left = F.SurfaceSubdomain1D(id=1, x=0.0)
boundary_right = F.SurfaceSubdomain1D(id=2, x=L)
my_model.subdomains = [w_subdomain, boundary_left, boundary_right]
import ufl
    PulsedSource(
        flux=lambda t: ufl.conditional(ufl.lt(t, 5.0), 0, 1.0),
        distribution=lambda x: ufl.conditional(ufl.lt(x[0], L / 2), 1.0, 0.0),
        volume=w_subdomain,
        species=mobile_D,
        subdomain=boundary_left,
        species=mobile_D,
        value=0.0,
        subdomain=boundary_right,
        species=mobile_D,
        value=0.0,
final_time = 10.0
    atol=1e-10,
    rtol=1e-10,
    max_iterations=50,
my_model.settings.stepsize = F.Stepsize(initial_value=1)
my_model.exports = [F.VTXSpeciesExport(filename="out.bp", field=mobile_D)]
In this example, the flux value is 0 before t=5 and the flux distribution is 1 on the left half and 0 otherwise.
Concentration for t < 5
Concentration at t=10
You can even further simplify your model by simpy doing:
def flux(t):
    return ufl.conditional(ufl.lt(t, 5.0), 0, 1.0)
def distribution(x):
    return ufl.conditional(ufl.lt(x[0], L / 2), 1.0, 0.0)
    F.ParticleSource(
        value=lambda x, t: flux(t) * distribution(x),
        volume=w_subdomain,
        species=mobile_D,
I see, I am trying to create the flux and distribution functions as ufl conditionals now.
Thank you very much for your help!
Yes for now ufl.conditional objects are easier to work with (inside FESTIM) than python functions. Though I understand python functions are often more convenient for users…
